Nanjg 105c running with 2x18650?
Well, i need to replace a TF x8 driver, but since its 23mm or something and i dont wanna wait i was thinking can i use Nanjg 105c instead( piggybacked)?
The flashlight has 2x 18650 batteries, so i was wondering whats the easiest and most reliable way to mod the 105c in order to work
Dont want for him to drive MGT2, just XML2
It would be a lot easyer to drive a MT-G2 with that.
Just the Zener Mod and good to got.
For a XM-L2 you need a buck driver.
Yeah m8, the problem is i am out of a MTG2s atm, and the CHina spring festival is starting….not a proper time for orders :~
Plus, i dont actualy need that power, that FL is sitting as a backup in my wifes car
OK, then I would just use a 18650 dummy (piece of round wood) and use the light with one 18650.
With an even number of LED’s like that you can wire them 2s4p, that will be the same as wiring 4 6v emitters in parallel and will work perfectly from your 2s 18650 config.
Note being a backup light for your wife’s car L4M4’s way will definitely be safer in the long run. Plus easier to monitor voltage on.
