Misiek_86
(Misiek_86)
1
Hello, I’m looking for the Nanjg 105D driver schematic for 6xAMC and 8xAMC, it’s all about this:
- 4.86€ |AMC7135 * 8 fahrer 3/5 modi Taschenlampe platine Anti reverse led treiber|flashlight driver board| - AliExpress
- Page Not Found - Aliexpress.com
Someone has a schematic, I would be grateful if you would share it with me
I know I can buy a ready-made driver. But I would like to order PCBs and solder the elements myself, then upload some software for 105D.
Jerommel
(Jerommel)
2
With the same components you could build a 3 channel driver, driving 3 banks of 7135’s.
Low = 1x 7135
Mid = 1x 7135 + 2x 7125 (3 in total)
High = 1x 7135 + 2x 7135 + 5x 7135 (8 in total)
The benefit would be that you don’t need PWM.
But you could use PWM for even lower modes (on 1x 7135)
djozz
(djozz)
3
Some googling found the schematic for the NANJG 105C which should be the same as the 105D, or very close.
Misiek_86
(Misiek_86)
4
djozz: I checked the 105C driver, unfortunately the 105D code doesn’t come under 105C: / that’s why I’m looking for some 105D solution
djozz
(djozz)
5
I’m not sure what “doesn’t come under 105C” means, but I’m not a code specialist anyway so perhaps someone else can answer this.
Misiek_86
(Misiek_86)
6
I meant that I have a 105C driver, I put code from 105D on it and it doesn’t work e.g. memory mode, after turning off it still lights up from moon. That’s why I was thinking about making my own driver under 105D and then I could understand it, because most of the codes are made under 105D.
djozz
(djozz)
7
Ah, a few things are different then.
Misiek_86
(Misiek_86)
8
Could you write something more about this solution, do you have any schematics or link?
That’s why I’m looking for a 105D schematic
From what I hopefully understood in this thread (link below) the 105c and 105d are very similar but with a few changes. It was evidently a creation of simons at convoy flashlights. Others have reprogrammed them so it can be done.
I found a little more info here. I need a help with NANJG 105D driver program.
Edit: I missed the important part of your OP, you wanting to create your own pcb’s like the 105d. That’s why you need the schematic :person_facepalming: .
Maybe this could work for you? OSH Park ~
