Congratulations on the new store site! While you’re adding products, could you take care of some license compliance issues?
Each product which uses GPL-based open-source code needs a notice on its product page and a link to the source code which ships on that product.
The items I see so far which still need this added are:
  • Lumintop GT Mini
  • Lumintop BLF GT70
  • Lumintop BLF GT
  • Fireflies ROT66
  • Emisar D4S
If you’re in the business of distributing products based on open-source code, you need to be familiar with the license. Here it is in English and two translations:
Specifically, sections 4 and 6 are the most relevant — “Conveying Verbatim Copies” and “Conveying Non-Source Forms”. The easiest solution is clause 6b2, linking to a copy of the sources.
The link needed on the product page depends on which firmware the light has:
  • For Anduril-based lights, the source code is here.
  • For newer Emisar lights with RampingIOS V3, the source code is here.
  • In case you add any older Emisar lights with RampingIOS V2, the source code for that is here.
  • For Narsil-based lights, things are a little more complicated. There are a lot of different forks of NarsilM for different lights, and they’re not all available in one place. However, I’m trying to clean up that mess and get the forks all merged together again. When that happens, the code will be available here.
The text to put on the product page could be something like this: “This product uses free software distributed under the terms of the GPL v3.” The link there should go to whichever firmware the light uses.
