There is no 3 cells to one XML driver with 17mm I can remember…
The driver TiVo linked is the only driver which is almost what you want, the driver board is about 19mm in diameter and 9mm thick…
The picture of the lamp shows AAs…length 200mm….have you really modded it to 3*18650s?
If you open up the driver end of the pill the 19mm driver should work. If its similar to the KD super P7(sold just about everywhere it seems) the efficiency runs ~85% on high See here
Those numbers might get better with multiple LEDs in series or running an mt-g2 but it needs a bit of overhead. I’ve used it to power LEDs in parallel from 6V and 8.4V nimh packs but run time never seemed to meet expectations.
The driver you linked is one of the ax2002 or similiar ones….and fills not your own specifications, it’s low current single mode and a buck driver….lol
But yeah it is 17mm…. :bigsmile:
These buck drivers can be resistor modded to some amps so it might reach your minimum specification of 2.xA, I believe fastech has a similiar one for 1.5$, I have tested with 6V but nothing above…no modes, no high current and not very good on low battery voltage…
What led do you use? This drivers need around 0.5V higher voltage input than led forward voltage…
I think the closest thing would be a Zener modded 105C but only for closely matched input/output voltages(3S xp/Nichia on 20mm) or mod the light to 3P. There a blank area in the driver spectrum shaped like your description but the size restriction can be worked around with p60 format. Match put a 19mm driver in a AA Minimag.
