I’m looking for a driver for a 2 x xml mod I’m going to try, needs to work with 1 - 2 li-ion so 4 - 8.4 volts
only one I’ve found so far is the manafont 3t6 driver though I’m not sure if that works with 1 battery? or what amps it gives though I think I read it gives around 5amp out which should be fine. Could always be reduced with a resistor change if it’s too high anyway I guess?
Any one know of any other suitable and cheap drivers for this task or if the above will be fine?
I used this one from IOS for my Torchlite build and a MT-G2 LED. Even tried it with a single XM-L2. I don’t know if the diameter is fine for your project, but if you purchase it, include a note specifying whether you want a 3-mode or 5-mode.
I have one of those boost/buck drivers from int-outdoor on order. Might use it for several projects since it seems to be quite versatile. It is the best option I know of.
The manafont driver I believe will give give out about 4,5a without resistor mod. Nothing more… Resistor mod will give you more output.
I doubt it will work with only one cell. It is made for the TR-3T6 without extension tube as far as I know. Using 2 batteries only.
think I’m just going to get the 3t6 driver from manafont, it’s just so cheap compared to the other one mentioned and thinking about it I don’t really need it to work with 1 battery anyway and I can always change it later on if I wanted.
There is also a one cell 5A driver out there and a lot of direct drive drivers.
If you can go with the 3t6 driver you won’t regret it, it is a really nice one.
