NEED AAA Reflector for XPG-R5
Hi Guys I have modded my Ultrafire x1 with an old XPG-R5 led given by Old4570, But the beam profile is no good.
It uses a 12mm wide by 10mm deep XR-E reflector.
I need some one to recommend a new reflector if you have a xp-g aaa light, can you post a pic of the reflector.
I don't know of any reflectors off the bat. You may be able to improve your beam significantly if you can back the emitter out of the reflector a bit. Since the light emitted from the emitter is not 180 degrees, it appears that the lower part of your reflector may not be getting any light to reflect.
A standard XP-G LED isolator may be thick enough to do the job. Of course, you need to have room to for the cell with the pill sitting back further.
How about this offreing from Dialight ?
Might need the slightest bit of adjustment to clear the solder blobs
