Need advice on a budget thrower
Hi folks,
First post and I’m loving this site so far.
I’m looking for a budget thrower and after perusing the forum, it looks like consensus points to a Jacob A60. I found them at DX and one other place but was wondering if some regulars could post maybe a top 3 or a top 5 of your favorites to work off of while I’m looking for others. Thanks.
Welcome to BLF!
UltraFire/TangsFire HD 2010 is my best thrower: http://www.tmart.com/UItraFire-CREE-XMLT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Gray_p135765.html
Hi Jay,
Welcome to the BLF !
The A60 is a great thrower, but has a very narrow beam and small spot. If you are looking for a larger (albeit more expensive) light with greater overall output, the SkyRay STL-V2 gets good reviews here. Its XM-L LED makes for a more useful beam, IMO.
The Ultrafire HD-2010 is a very good single-cell thrower, and is also 26650-compatible for greater runtime.
Good luck with your search.
EDIT: BetweenRides beat me to the punch !
I like the additional power the XM-L powered STL-V2 light has. With the big-reflector XR-E lights (like the Jacob A60 and similar), you get a more throw, but with a very narrow beam. The XM-L gives you excellent throw, but with a much larger spill making it generally more useful.
http://www.manafont.com/product_info.php/sky-ray-stlv2-cree-t6-adjustable-or-modes-led-flashlight-2186503163403cr123a-p-7191
For $24, the Small Sun ZY-T13 is supposed to be a decent thrower; ILIKEFLASHLIGHTS really liked his:
[quote=ILIKEFLASHLIGHTS] ...if you want the best XM-L bang for your throw the Small Sun ZY-T13 is the way to go. But it won't out throw the STL-V6. But for about half the price, I know of no other XM-L flashlight that will touch it for money in value, brightness, perfect beam, or throw. I like it so much that I have 2. [/quote]
http://www.manafont.com/product_info.php/small-sun-zyt13-t6-5mode-1200lumen-led-flashlight-black-218650-p-10728
Welcome to BLF! You’ll love being here! :slight_smile:
Fandyfire STL-V6 (= Skyray STL-V2) is my favorite, but it requires more attention because of the 2x18650 setup. It’s very nice thrower for you, but only if you are willing to check the cells regularly…
Jacob A60 is good, but the beam is very thin.
I don’t have the HD2010, but that might be good single cell alternative.
There’s the other smallsun the zy-c08? Is it? Again, ilf raves about his, tbh I nearly pulled the trigger on this myself (which would break a promise to Mrs gords) glad I didn’t as I’ve found I’m skint. :frowning:
Is it the T08 here?
http://www.manafont.com/product_info.php/small-sun-zyt08-xml-t6-1200lumen-5mode-led-flashlight-black-218650-p-11600
Looks decent, I like the side-by-side cell arrangement. Should drop into a back pocket better then a end-to-end light... I may have to add one to my to-buy list as well...
<edit>Looks like it is; here's ILF's review on it... Really makes me want one now...
Welcome to the family, Jay!
BetweenRides called it when he recommended the HD2010. Awesome light for the money. The A60 just puts out too narrow a beam to be useful IMO. A large head XM-L thrower like the HD2010 will throw as far but with a larger, more useful spot and plenty of side spill to make it an all around useful light while you shop for others. The ability of the HD2010 to run on 26650 cells gives it great run time too, but still allows you to run 18650 if that's all you have available.
ILF said the T08 throws even better than the T13 and after seeing his pics I’d agree. The T08 is on my short list and the cells run in parallel @ 4.2V instead of series @ 8.4V. Nice!
The good old C8 XM-L U2 is a pretty decent thrower, although not as good as the Ultra/Tangs/Fandy-Fire HD2010.
And the C12 is also a great thrower, it is cheaper, lighter and smaller than the HD2010.
I bought this Ultrafire C8 U2 thrower and I am very happy with it.
Also consider this Ultrafire C12 T6
1. STL-V2 running 2 x 18500 or 1 x 18650 with host from C8 - bright and the ultimate thrower!
2. HD2010 - short, bright, throwy to a fault! My favorite, really.
3. UF C6 (aka YX-009) with car and wall charger Q5 XR-E - not that bright, but super throwy and goshdarn cheap.
You cannot go wrong, my friend! These are amazing throwers! You need them all!
Welcome, btw
My modded Small Sun T13 throws better than my eagletac M3C4 XML, not bad for a $24 light!
Depends how narrow a beam you can live with. Me, I mostly want a wide beam with plenty of light.
Unless I’m on holiday at my family place in the middle of an enormous forest - the narrower the beam the better there - all those trees get in the way and high power lights just lose all vision for anything that isn’t touching me.
I’ve little or no use for serious throwers.
They are fun - but are little or no use for finding black dogs (I own two of them - both very large) at night.
Depends what you want them for.
For me sheer output beats throw every time. If you shine enough light, at least some of it will get to where you want it to be.
That’s so easy.
FandyFire STL-V6 from Deal Xtreme for around $45 shipped and puts out around 50,000k. The Small Sun ZY-T08 for $26.26 shipped from Manafont is probably the best thrower XM-L light out there for the money at 41,000k. It’s also the best quality light I have seen for the price.
I did mean the t08, I don’t own a thrower per se, its either that or a hd2010. As don points out, their little use to us in the UK, but I guess fun non the less. :bigsmile:
In terms of budget thrower lights it varies. For starters, it will depend on how much you are wiling to spend. For the cheapest your best bet will be the Jacob A60. For a higher price the STL-V6. Other factors are how far of a throw you want and what will it be used for. As others have mentioned, the A60 has a very narrow beam but reaches quite far. The STL has a bigger beam profile and has good throw but at a higher cost.
Good luck with your research.
I’m probably leaning toward the STL-V6 but above, the says only if you are willing to check the cells regularly. Is there an issue when using multiple batteries?
ICR Li-ion cells are potentially more volatile and require a little more thought in use. Running them in series or any multicell setup has potential greater risks.
That said, there are many many lights on the market using this setup and we are all quite happy dealing with volatile things like petrol (gas) in our cars on a daily basis.
If you’ve not owned li-ion powered flashlights before, you might want to do a little reading up on them first to make sure you are happy.
If they concern you, then you might want to look for alternatives. Maybe something like the new 2D Pro from MagLite. It uses a 272 lumen XP-G (ANSI FL1 rating) and will throw pretty well. It’s also solid, well built, built in the USA and runs on 2 easy to get D cells.
http://www.officerstore.com/store/product.cfm/pid_9730_maglite_pro_led_2d_black/
I’ve got a 200 lumen XP-G MagLite and it throws as well as the Small Sun ZY-T13 (mentioned above), albeit with a narrower beam and not as bright spill. But I’d certainly class it in a similar league in terms of effective usefulness.
Welcome to the madness, Jay in WV!
