Need help finding a solar power meter (amp hours, watt hrs, kilowatts, IN/OUT
So there are a ton of volt/amp meters and the like on fleabay and chinazon.
I cannot find a meter that monitors amp hours, watt hours, kilowatts accumulated in/out (bi-directional) in large amounts over a period of time. Icing on the cake would be total accumulated and daily accumulated screens. More icing would be one do-it-all meter instead of 2 (1 for in and 1 for out).
So to recap
Amp hours accumulated
Watts hours accumulated
Kilowatts accumulated
I have meters on solar charger and samlex evo inverter/charger/transfer switch that give me amps, volts, ac amps, dc amps, battery volts etc.
Many charge controllers have optional battery monitors. I added a Whiz Bang Jr monitor to my Midnight Solar charge controller. It monitors amps in and out plus shows percent charge. Its proprietary for Midnight Solar though.
There are very cheap add on monitors available from as low as 15 bucks I believe. Probably need to spend slightly more for state of charge display.
Check youtube video called how to monitor RV batteries on a budget. Has links for several.
I have the whizbang and all it does is monitor incoming ONLY from solar panels. Its not very accurate either.
Im looking for something that monitors BI-directional (whiz is IN only, 1 way ONLY).
AH in
AH out
W in
W out
KW in
KW out
daily
for all time
Also if you shut the kid off or it loses power all data is erased. Sometimes it just erases it anyways because its glitchy!
Don’t know if this helps, but I use this
Thanks, I think those are for rc cars/planes, not whole houses.
You are not going to run a whole house hardwired inverter pulling constant 200a through that.
Its also NOT bi-directional.
Anderson type 50-Amp connectors
  • 75A continuous / 200A Peak
Bogart Engineering Trimetric measures/records DC in and out of the battery. Does not measure anything AC.
I use it for my set up - a 250 watt solar panel with a MMPT regulator and a 100 ah lithium battery and a 2000W inverter - it reads both ways depending on how you plug it in. Did you read the manual? HERE
Are you running 200 amps through 1 12v battery and a ammeter made for 75a?
You will destroy that battery with c/.5 loads. Also voltage sag would shut that inverter off in seconds.
I did not read the manual because specs said 75a sustained for the rc hobby meter.
Sorry, I’m not understanding your question.
The link I sent is for is a passive meter that only measures stuff (both ways) and doesn’t change anything.
So I have, Solar panel - solar regulator - (above) meter - battery. I re-read the manual and it mentioned nothing about RC cars/planes.
The description on the website says:
The Watt Meter only requires a tiny 7mA draw to operate making little difference to power production during usage. Ideal for cars, boats, caravans, off-grid installations, Wind, solar installations, and so much more.
Features:
- Anderson type 50-Amp connectors
- 75A continuous / 200A Peak
  • Up to 60VDC compatibility + other things you can read on the website - maybe you mixed up the links?
I was just trying to advise you that the unit is not made for the loads you are feeding it. It has 8g wires and those can handle 50 amps. Not 200 amps. I use 3/0 welding 600amp cables to my batteries.
Yeah those little meters are fine for a small solar/battery setup, but not designed for what the OP wants. My kids bought me a similar one for Fathers Day, then I bought two from the usual suspects for $10 each and put my own Anderson plugs on them. The problem with them is they are using 16bit chips so will only count up to 65,536 so it’s no good for logging the total Amps over a week or so. (AFAIK anyway)
All grounds run through my Whiz Bang and show amp usage both directions. It records total amps also but with my controller resets after the sun goes down so other then daily no logs are saved. Seems to be fairly accurate also.
No comments on Bogarts Trimetric? I installed one 12 years ago. It was a different model than what is sold today.
