I am trying to fit an 18650 in a shorty L2m while retaining the rear-clicky. Obviously space is very tight, so I need help finding a very short single optic or reflector. I’m not too worried about beam profile, very floody is fine. I honestly might be fine with a mule beam profile, but I just think mules look tacky and unfinished. If need be I could easily switch to an 18500 or use the 24mm quad optic, but I really only want a single emitter.
It needs to be 26-28mm diameter and as short as possible, definitely under 10mm tall.
Anybody have any ideas?
I suppose I could also use a fixed aspheric lens. Though it would have to be very shallow as well, I don’t want to change my bezel and the light must headstand.
I guess it should work, but will be floody with anything, 64deg with XP-E. In contrast some Carclo multi LED will be you a much narrower beam at the same height. (e.g. 10508 24deg with XP-E2)
good! care to share? I googled it and checked mouser, digikey, farnell, arrow, ebay and a few others I can’t remember the name of. They all came up as non-stocked or backordered.
