Is it possible to increase the current of this driver?
Lower resistance means higher current.
Try add 0,5 ohm resistor parallel or use 10-turn 10 ohm potentiometer.
Thanks maciex93, this driver is from old olight m21. It has four modes, if i change these resistors will i lose the modes?
No.
The resistor marked 273 (27K ohms) looks like a pull up resistor. The other 2 marked R10 (.1 ohms) looks like the sense resistors.
