I need help you BLF battery guru’s. I build game cameras for use on my hunting property. I’ve actually not built a new one in a couple of years and I’m looking to build a few more and to modify some that I already have. I have a fair amount of 18650’s and I got to thinking that I may be able to include them in my builds. I have 3 scenarios that I need help with.
First, most of mine are based on older cameras that still use AA x2 batteries in series so 3.0V. Currently I am running Eneloops in the camera and I’m running secondary C or D cell alkalines to recharge the Eneloops as they are drained. This works well, except decent quality C and D cell batteries aren’t cheap. Cheap batteries like the Sunbeams just don’t last at ALL. A lot of night pictures will run through even the best of alkalines in a couple of weeks. If I run 18650’s in 2P, I think I should have a greater amount of usuable power than 2 NiMH AA’s and 2 alkaline C’s. I may be wrong though. Problem is, how do I efficiently regulate the voltage down to 3v so I don’t fry the camera. Do you think this would work or is even worthwhile?
Next scenario, I have some cameras that I set up for IR. I basically removed the IR filter from the camera, changed the cap for the flash so that it is at the very minimum. I use a camera slave flash with IR film over the lens. There is a control board that with a peanut that senses the weak flash and sends the signal to the slave flash to fire. The slave flash originally ran on AA x4 in series so 6V. I currently use either 4 C or 4 D cells to power the slave unit. I think that 18650’s in 2S2P might fry the slave at the over 7v. any ideas?
Lastly, I wonder if I could just use IR LED’s in parallel instead of using the slave, but I don’t know how I would go about making that work. I have to have a driver that was constantly on high. As I currently use the slave, the sensing control board sends a signal to fire. The slave always has power, just doesn’t fire until told to. I’d have to make it where the control board actually will turn on from the signal from the control board.
How about two protected cells in parallel feeding the camera through a rectifier diode (not schotky) to give about a .7v drop. Nice and simple and no parasitic drain.
I bought the parts to set up a similar camera in our woods when something was eating sheep next door but didn’t know what to use to trigger the system, is that a PIR sensor on the front?
I wonder how long 2P would last as they would equalize with the AAx2 once they reached 3V.
Yes, it’s a PIR with a control board to turn the camera on and trigger the shot. On feeder mode it will trigger a picture every 30 seconds as long as it senses motion. On trail mode it will trigger a picture every 2-3 seconds as long as it senses motion.
That depends on your charger circuit, or if you just used a diode. You wouldn’t want to run them much lower than 3v anyways. Your eneloops are probably about 2000mah in series, so if you ran 2 NCR18650B’s in parallel with a diode to drop voltage, thats an extra 6000mah, 4x the original run time.
I’ll be using the 18650’s to charge the eneloops as they are used. I’m currently using 2 C cells to do that. So I’m not comparing the 18650’s to the AA’s, I have to get the voltage down to 3v and compare my setup to two C cells in series. Figure 8000mah or so for the 2S C cells, and they can be drained to about 0.9v each. I don’t believe the voltage will cross back to the to equalize the C cells, but I may be wrong. I know alkalines drop their voltage pretty fast though compared to lithium, so the lithiums would be useful for a longer period of time. I’d likely have to do 4P 18650 to get the same usage.
Maybe it’s worth to check your cameras input voltage range. Many cams can run on USB 5V. Some of them accept anything 2,5-5V on the battery terminals. If so you could run it 2P without any AAs, diode or loss.
Or use a powerbank(with high efficiency boost/buck) module to step 2P up to 5V USB or 2S down to 5V.
a 18650@3V has not much usable capacity left. Anything over 3V will just be concerted to heat by overcharging the AAs.
so toss the AAs and go 18650only
Sorry I misunderstood. I thought the goal was just to have rechargeable options. If longer runtime is your goal, you’ll definitely need to go with more than 2P 18650’s.
I could do that. If the 18650’s were regulated down to a 3v output, then I wouldn’t think they would overcharge the AA’s. The advantage of what I have now is I believe I get an extra 2000mah by keeping the AA’s. The C’s drain down charging the AA’s then once too low I still have the AA’s left. It’s basically AA 2S parallel to C 2S, but the AA’s shouldn’t charge back to the C’s. With the 18650’s doing the job of the C’s I think they would end up neutralizing at some point where the AA’s would start keeping the voltage up in the 18650’s meaning less useable power to the camera. I could always add another 18650 and do away with the AA’s, but that is further increasing the space if need for batteries. I’m not sure about my assumptions which is why I’m bouncing it off you guys.
Maybe I’m asking to have my cake and eat it too. I’m looking to not have to buy alkaline C’s and still have the same runtime as I currently have or possibly more without having to use a huge project box to support the size of all the cells.
