Need help in recognizing wiring in a driver
Hi,
I bought a chinese (uranusfire) light with a momentary switch.
I want to change the driver, but leave the momentary switch.
The momentary switch has a led battery indicator: Blue: battery ok, Red: battery low.
I want to wire a Qlite momentary driver to the momentary switch.
Hiw do I recognize the 2 cables that should be connected to qlite stars?
The momentary switch module has 5 cables:
vcc, groud, k, r, g (probably not ground)
Here is the photo of the momentary switch itself:
Any help will be much appreciated :slight_smile:
What I would try is using a DMM on the continuity mode. When you press the momentary switch it makes contact between the two sides, so contact different combinations of wires with the DMM then press the switch. When you hear a beep while pressing, those are the two switch wires.
Thanks:) I found it. It was K ang G.
