Need help looking for a reverse clicky for my SolarForce L2T
Hi. I’m looking for a reverse clicky to replace the stock forward clicky on my SolarForce L2T. I don’t really have a budget set for this, though admittedly I’d prefer not to spend as much as the host itself cost. I saw a reverse clicky switch on SolarForce Sales (link: here) which will apparently fit all 2011 L2P’s, but I’m not sure if it’ll fit my L2T or if the switch size is different.
Also, I hope you don’t mind if I bundle in another question, but I scuffed up the bezel pretty badly the other day and I’d like to get a replacement to make the light look a little bit better. I liked the look of the B6 bezel (link: here), but I’d like to get some opinions on whether it would look good on the default L2T head.
Thanks in advance.
I think that will fit your L2T. As far as I know all the L2 series swap out.
If you want to be sure, disassemble the L2T tail switch and measure the diameter of the switches PCB. If it’s 20mm, you’re golden.
The switch measures 19mm at it’s largest point and the cavity measures a hair under 20mm. Do you reckon it’ll fit? :~
The reverse clicky Solaforce switches I have here are pretty much exactly 20mm in diameter. 1mm is a bigger difference than it seems in these situations.
You could always just contact SF sales to confirm before you buy one.
I’ve tried what you are proposing and it doesn’t work. At least I couldn’t get it to work. The RC switch that they sell will also not work in the new L2N, L2m, or the P1s. Ya, tried in all of them as I really like the host, but hate FC.
It any of you real falashiholics have a way to do it , Default Username isn’t the only one interested in a solution that gets the L2 Rç into other SF hosts.
I went ahead and ordered the reverse clicky and B6 bezel along with the L2M and Intl-Outdoor drop in that my buddy wanted. I figured that I might as well toss it in with the other items I’d be purchasing from SF-Sales, and for $2, I’m not going to complain if I can’t get it to work. I’ll report back if I manage to modify it to fit.
Thanks for the help.
Any luck?
Or has anyone got a line on 19mm reverse clickies for SolarForce tailcaps? :weary:
I was also wondering about how to get a reverse-clicky into a new L2N (yet to buy).
-Garry
I’m ashamed to admit that as soon as the reverse clicky arrived, I placed it on a shelf for later modding and promptly forgot about it. I can at least report that Cone’s advice regarding the switch fitting in the L2T was absolutely correct though; there’s no way you’ll be able to install it in the L2T tailcap in it’s unmodified form.
A couple of thoughts did cross my mind on how to modify it to fit though. For one, it might be possible to shave off a hair from the diameter of the reverse clicky PCB with a lathe or a more crude setup, though one of the implications would be that the original retention “ring” (the aluminum disc that secures the switch) would have to be bored out to accommodate for the larger spring OR the spring would have to be swapped out with the forward clicky spring. And to add to this, the clearances around the reverse clicky switch would be tight; I have a feeling that the switch would stand a good chance in shorting out against the clicky body once installed.
Another, perhaps more practical, idea would be to unsolder the reverse clicky switch from the PCB and install it on the forward clicky PCB. There would still be the problem of isolating the switch leads from the tailcap body to prevent a short, though I reckon it’s doable without too much effort.
And on a final note, I’m not too good at identifying these sorts of things, but it looks to me that the switch PCB is made out of fiberglass. If you do happen to try shaving or grinding off a bit from the PCB, please take the precaution of wearing a particulate arrestor. You don’t want to have bits of fiberglass trapped in your lungs :stuck_out_tongue:
