need help ssc p7 fauly driver ?
ok so my trusty ssc p7 single mode has given upon on me
ok so the bottom left you can see the problem
i was looking to replace the driver
but i am struggling to find a single mode driver
perhaps the good ppl here can help me out or maybe even suggest another alternative
i'd rather keep to a single mode and this body as it has taken me a while and several other models to find one that i liked
the driver is 17mm in dia the pill is 24mm at the top with a small recess of 10mm dia where the led is glued to it
the refector is an op 42mm dia and 32 in lenght and the pill screws in to the head just at the crome seen in the top right picture
Here is a single mode driver or here but it's driven at 2.8Amps
If you buy it please post some pics. I think it's the 5 mode version that you can mode with solder and delete Medium, low, strobe and SOS.
thanks the single mode one will do the trick
i an currently awaiting delivery of 501B XM-L U2 1300L 5-mode LED Flashlight from them so i will see how they handle deliver of that before i order the driver
i am cosidering using the led and driver from that on this host but that will depend largely on the beam of the 501b
