need help to find correct drivers for Quad/Triple leds
Hello
Need advice/help on building 3 flashlights(s11) with quad or triple ,but i cannot find the correct driver to use,i dont mind about modes ,all i need is 1 mode 100%
4x LUMINUS SST-10-IR infrared LED 850nm 940nm
Voltage : 1.2-2.0V
Max current : 1.5A
with 20mm copper DTP MCPCB for 4*3535 LED 2s2p
for this i guess a 7135 single driver with 3Amps will be ok,but i am not sure
Quad/triple paraller or 2s2p
LUMINUS SST-20-DR 660nm deep red LED
Voltage 2-2.6V
Current Max 2A
3v 8A buck driver maybe
LUMINUS SBT-10X-UV UVA 365nm LED
VF:3.8-3.9V,When the current rises to 3A, the voltage will reach about 4.5V.
OR
NVSU233B(T) 233B P9d22M 365nm UV LED Vf=3.6-4.0V
IF=max 1400mA
same problem have not idea what driver use
any advice is welcome,thank you
up found about 1 and 2 ,need help for driver with the quad/triple UV leds.
For the UV I’d go with tripple parallel and a fet driver. The leds will never see the full power as the fet/direct drive will only supply max 4.2V of the freshly charged battery minus the resistance of the system. So basically almost zero losses but also zero regulation meaning it will dim as the battery drains. A 21700 should last you quite a while especially if you use a linear+fet driver for the lower levels.
For IR emitters this is going to be crazy inefficient (as in under 40% driver efficiency), I might even worry about the 7135 chips burning up from absorbing so much excess voltage.
If you want 3-ish A drive current, I strongly suspect that the 2.5A red light driver will work. In theory you can also resistor-swap the 1.5A IR driver to increase the current, but I haven’t tried it yet and don’t know if it will overload the inductor.
thank you both for your comments!
i thought 7135 specs was up to 7v , thats why i select it as good candidate
The 7V is likely input voltage rating, which isn’t the whole story–you need to consider the input-output gap.
A 7135 chip is essentially a fancy resistor that burns off the excess voltage as heat. If you are driving an IR LED from a full cell, the power dissipated per chip is (4.2V-1.5V)*(0.35A) = 0.95W, which is well over the 0.7W threshold for requiring additional heatsinking, per page 4 of this datasheet.
For IR if wired 2s2p a 3A linear driver will work rather good except dimming on the max level. The rst should be ok-ish regulated
2S2P would indeed be a great solution for 3V driver compatibility, provided that OP can either (i) source a MCPCB with this configuration or (ii) modify a MCPCB by cutting some traces and bridging some contacts.
yes i will use this : 20mm copper DTP MCPCB for 4*3535 LED - Convoy flashlight
Excellent! It just occurred to me to look this up a minute ago–somehow my brain initially discarded it because quads instinctively makes me think of Carclo-compatible MCPCBs. But this does indeed work, and one question on the product page mentions your application.
The quad setup has the mechanical dimensions of a single 7070 LED, so the 11mm opening S11 OP reflector could work, though it will make a very ugly beam with a giant hole in the middle. You will want some strong diffusion, like frosted tape on the lens.
most probably ,all the flashlights will be mules without reflectors.
will a driver like this : https://convoylight.com/products/22mm-6v-8a-driver-for-xhp70-3-led-input-3-4-2v-output-max-8-25 be ok for 4 paraller UV leds ,or it will fry them?
It’s a boost driver so it won’t be able to regulate anything. Another option is using a buck drive that can take 2 cells and use 2 18350 in series.
thanks ,i wanted to avoid the 2 cell option ,so i guess my only option if the fet.
You can use a boost driver but with the leds in 2s2p configuration. The convoys 20mm 4 led mcpcb is designed for that anyways.
This is a 2s2p config
i have that pcb and will use it for my infared setup ,i was afraid that the 6v boost drive will not be enough to feed the UV leds ,since they need 4v each.
another option is this series pcb Emisar Noctigon XP Raw MCPCB/AUX Custom – JLHawaii808 with 12v boost driver.
found someone with similar setup of the build i want to make : What did you mod today? - #10493 by zumlin
as you said 2x18350
