Need help with 30Q acting strange when charging
After about 2 hrs of charging three 30Qs that I used in my ROT66, something odd is happening with the battery in bay one as you can see in the pic below. It is stalling at 3.95 volts but the mAh keeps rising and is out of sync with the other two batteries? It's displaying about 60% more mAh than the other two even though they were used as a group in a flashlight.
The other two batteries terminated at 4.1v, shortly after I took the pic below, which is what I set my mc3000 charger too, and have almost identical mAh readings. But the first cell in bay one is going screwy. I got these batteries from illumn last month and all was fine and I used them in my Q8.
Then yesterday I used them in my rot66. They went in the rot66 with identical voltage and were removed with identical voltage and had similar IR readings when I put them in the charger. I just unplugged the charger as it seems the first battery is failing. It's not overheating and had the same temp as the other batteries, so it's kind of odd. Any ideas? I switched that battery to the other three bays and all are giving the same V reading so that rules out bay-1 of the charger not reading it correctly.
Did you try to charge it to other bays - besides the volt reading - and it behaves the same way?
Does the battery stay warmer than the other two when you put it aside for let’s say 30minutes?
Didn't want to charge it more as these batteries were married in the Q8 as a group of four before I removed one and used them
in the rot66 as a group of three, so it doesn't make sense that one cell all of a sudden is needing 60% more capacity and still
only at 3.95v while the other too have terminated at 4.1v.
No, they all stayed cool.
My thought is that, maybe, channel 1 of your charger malfunctions and never charges the battery, only shows that it charges it. So, if you place it on another channel / slot or another charger and it charges as it should, the problem is channel 1 of your charger. If the battery behaves the same way on another channel / charger, then the battery is not working properly.
By the way, I had a battery (Panasonic 18650PF) once which was charging upto 3.8-3.9 (I don’t remember exactly) and it was very hot while charging. When left outside the charger, the voltage was dropping rapidly, so I guessed the battery was shorted inside and I threw it away. But, on contrary with yours, it was getting really hot.
That makes sense. Ok, will try it and see how it goes. Could be that the mAh reading is completely false on bay-1.
Looks like Bay #1 did fail. 250mAh on my other battery already and voltage has not changed from 3.80V. Going to leave it there a little longer, but it's not looking good at the moment.
