Need new glass for my Convoy M2 (New Version)
Yes, mine broke! My P60 lenses are a mm too big!
I got an AR coated at Kaidomain some time ago.
But it’s a bit thicker than the stock one.
Any idea what size my is in bits..
Have you contacted Simon at his aliexpress store? He might be able to do something for you.
From memory, I know 24mm is way too small, but I thought a P60 was 26.5mm. Not sure though.
28.9 x 1.7 mm
Convoy M2 matte version with shelf (no pill)
Mine is a year old, so dont know if it’s your version.
Inside the head from threading to threading is 29.3 mm
edit:
Kaidomain has a 29.0 x 2.0 mm lens for 1.59 atm. Perhaps the one @gisewhcs was talking about.
Width should fit, height might be tight, as the o-ring is already only 1mm.
THANKS
Did you check here ?
Did you measure your reflector ?
Should give you close Idea of size.
