Need Recomendations for Flooder for Home Inspections
The light will be used in a lot of crawlspaces, basements, attics, etc—and throw isn’t too important, as it will likely only need to throw the length of a house or lot.
Would like to be able to light a room or space without having to sweep the beam.
( and already have a P60 w decently floody manafont drop in that will be used for backup, as well as a 2 x AAA Penlight to keep ready)
I was thinking multi cell for runtime, and also that a more modestly driven light would be better for extended use without heat issues.
I like the King—but the 4 cell light seems a bit wide to carry , and I hear that thermal properties are not great.
I'm setting up UF S5's (cheap 18650 tube lights) with about 2.1A and 45 degree angle TIR optics - one I did at 1.4A and it's pretty darn nice for what you are talking about doing. I'm going to do a XM-L2 3C TIR S5 for a guy who's got a biz buying/selling old cars for doing close inspections. I'm figuring a soft neutral, wide angle with no hotspot might just be ideal for this, probably same for house inspections too. I'm custom programming these with 4 modes: hi-med-lo-moonlight. Just my opinion...
The ZL SC600II has a great floody beam if that’s within your price point. Runs on a single 18650, but very programmable.
Armytek Wizard Pro. It provides the most even beam I've seen on any light. The closest thing is a zoomie on full flood, which is something else to consider if you want to spend very little money. The hotspot most lights have might distract you from noticing a problem elsewhere.
I had a similar need, and chose the Fenix PD35.
For the penlight that will brighten up a room and will probably be all you need, I suggest the TANK007 E06. It's floody and it's bright, plus it can be had in the US.
Under houses, and in attics, one needs a heck of a lot of light to be able to see well and at a distance.
you may want to get a high cri emitter
For checking out houses I would opt less for high CRI but get a neutral. High CRI is nice but they tend to be too warm to easily tell colors apart. Accurate color rendition is a combination of CRI AND color temperature. A lit candle is 100 CRI but is so warm as to make the cool colors almost look black and make warm colors stand out a bit too much. High CRI warm LED’s are great for outdoor use mostly because it mutes the greens and highlights browns and reds which most outdoorsy types ie hunters need. But for overall color rendition a neutral white will be better for objective visual comparison. This is especially true for the Cree XM-L neutral white. The ones in both my LXP’s do quite well and actually have better color rendition than the built in flash on my Canon camera.
My recommendation isn’t sold anymore, but it was the LXP 18650 light from intl-outdoors. But a similar light is the Roche F12. I like intl-outdoors because you specifically get to pick your led tint in this case neutral white is what you’ll want. Also you can pick your driver modes and you can leave out entirely the stupid blinky modes. This lets you pick a low medium and high so you have high for when you need tons of light but low and medium for very good runtime. On the stock driver and a 2600 mah battery you’ll easily get about 30 hours on low, 10 hours on medium (medium looks almost as bright as high so that’s saying something), and high which the light will get warm to the touch but it will go about 1 hour.
Plus the driver has no visible PWM which is an annoyance if you can see it or even walking sometimes you notice it because of movement. Keep in mind with the flashlight I recommended you can’t use protected cells which is less important anyways with single cell lights as you’ll notice the dimming long before the battery is severely depleted.
The beam shape will be pretty floody but another trick to really make these cylindrical lights really floody is to make a snap on diffuser using a clear frosted water bottle cap.
http://intl-outdoor.com/roche-f12-xml-mini-18650-black-flashlight-p-399.html
I took some photos for some reference here.
This one is lit with the flash. I used my Canon SX160IS. It’s rated pretty good in terms of overall color accuracy including the built in flash.
This is with the XM-L Neutral white run on high, on mine it is customized with a 2.8 amp high current driver but on the stock Roche and LXP it comes with a 1.75 amp driver. But there’s little difference in the tint between those two drive levels anyways. But you can see reds are just a little bit less saturated and blues and greens just a little bit more pronounced. And the yellow Kill Bill DVD is slightly greenish. But in reality you’ll never notice it because it’s so subtle. But I’d still give the flashlight the win because in noonday sun the blues and greens are more saturated than the flash photo reveals which looks washed out. My background wall is definitely a bold blue like this one and the flash washes that color out above.
This is a 90+ CRI XM-L it is warm white which is pretty much the only high CRI XM-L available. 2800k. My camera is actually struggling to accurately render the color. It really looks a lot more pinkish orange in real life. It’s pleasant to light up a room with but I wouldn’t call it accurate compared to the gold standard which is sunlight.
Overall I’d say pick the neutral white XM-L over high CRI if you’re doing inspection work it renders color more like noonday sun than any warm white high CRI led will.
I would get an Ealgetac MX25L3 with Nichia 219 emitters.
3 x 18650, twisty head for brightness, extremely floody
http://www.eagletac.com/html/mx25l3c/index.html
A Solarforce L2P. Yeah Yeah, I know what y’all are thinkin, but put an MT-G2 in it and run it at about 2.8A off a 105c driver in mule configuration. :slight_smile: Maybe even a little less amperage. You’d be talking 1500 lumens on high, but a nice useful low and general use med, could even utilize the moon mode. Do the resistor/zener mod to the driver and use 2 18350 cells. With an aluminum heat sink in the host at 7/8” diameter and slightly less than 1” long it would only be running into heat issues on high for more than a few minutes.
You can always just throw some dcfix diffuser on the XML p60. Makes the beam nice and floody but still has a little bit of throw.
Or you can also build a triple nichia219 for the p60. This will be a good floodlight plus high CRI.
If that had a true control ring with infinitely variable output, I'd probably be ordering another MX25L3. It looks very nice though.
http://www.eagletac.com/html/sx25l3/index.html
+1 on DBCstm’s comments about SF K-3 with the MT-G2.
I do home inspections for siding and window jobs, it’s plenty in stock form. Plus you already have the host body. If you need it smaller go for the L2M shorty host and put two 18350s in it, you will have no complaints trust me.
Its my go-to light in either 18650 or 18350 form. DBCstm’s mods turn it into a ‘masterblaster’, all you would ever need. And then some.
Sure, I suppose it would be possible to drive a Top Fuel dragster to the grocery store, but I wouldn't want to have to do it more than once.
18350s are pretty miserable when it comes to runtime, and two 18650s inline kinda doesn't meet the criteria in the OP. The light output for as long as it lasts would be OK but it's not something you'd want to carry in a pocket or use for a few hours at a time, no?
Two inline 18650s are not going to be an issue, small holster like for so many other lights. The Eagletac would be in between the SRK and the SF, no?
As far as the top fuel dragster, I would refer you to DBCstm, he does all that high end machine work in his state of the art workshop…
I build custom one-off creations too, also with minimal equipment, much like DBCstm. But I kinda get the impression the OP is not looking for a finicky and often temperamental hand-built custom thing. Not for a work light. The one-offs are fun, but much like dragsters, you wouldn't want to try to use one as a work truck 8-10 hours a day every day.
Zebralight S6330. Or Eagletac SX25L3 MTG2 version. Both are very floody, the eagletac offers a much better tint, the s6330 is much smaller. Both are 3x18650, so you'll have lots of run time, except on the higher settings which you're not likely to use much anyway.
If you're after a smaller size, the zebralight SC600II is perfect for indoor use.
But, SCK has a point…a stock Solarforce K3 with an L2P host, utilizing an extension tube for 2 18650 cells would have a decent run time, huge flood of light at the advertised 1500 lumens, and still have a nice low for an option as well as the working Med level for long term use.
Not hot rodded by any means, running moderate amperage but still making a ton of gorgeous light with it’s MT-G2 emitter. Kind of hard to go wrong with that one.
And my one-offs are seldom finicky (possibly temperatureforthemental though), working with the reliability of the better stock lights and certainly better than most any budget light.
Remember the day of the muscle car? Back in the early 70’s? How many horses did those bad boys make? Guess what? Mom’s going to the grocery store in a modern V6 making more ponies than the legendary Vette’s and Camaro’s of yesteryear! Literally “driving the dragster to the grocery store” every day.
