need some help with turnigy accucell 8150/power supply
ok, didnt realize this when i ordered but this thing didnt come with any instructions
and an even bigger issue right now is that the power input is alligator clips and the power supply i bought is a barrel connector
this is the charger
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7523&aff=261539
this is the psu
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20971
i suppose i can just cut the barrell connector off and use it that way? or solder another connector on the psu and input of the charger? i am a little hesitant to perform surgery on this thing
help? :~
will this work?
I'm truthfully not sure, I think it will though. Here a bump is for someone mroe knowledgeable. :D
Cut both the barrel and the alligator clips off.
The middle wire of the barrel should be positive which goes to red , other wire to black easy as .
I used some m/f xt 60 connectors from hobbyking for joining
The connector you have linked will work if you dont want to solder
Regards
Thanks
