Hi,
I am located in Europe and looking for a skilled modder to help me fix and upgrade two flashlights from my collection that are dear to me.
Here is the breakdown of what I am hoping to achieve:
Novatac SPA SPL-120 (Repair and Driver Swap)
Current State: The light was previously modified to host a triple Nichia setup, but it still utilizes the stock, original Novatac driver. Ever since the modification, it behaves very erratically it draws excessive current, loses its memory state, and often fails to turn on from a cold start unless I loosen and retighten the battery tube.
The Goal: I want to completely replace the original driver with an modern, programmable chip (such as an Anduril 2 driver or a customizable e-switch UI).
UI Requirements: I specifically want to configure the interface to have a momentary high (press-and-hold for maximum output) and a click-and-release low.
Future-Proofing: If mechanically feasible, I would love the driver adaptation to accommodate an 18350 battery tube modification down the road.
Arc LSH ( Simple LED Modernization)
Current State: Completely factory stock with the Luxeon emitter.
The Goal: A clean, straightforward LED upgrade. I just want to swap out the old Luxeon emitter for a modern, high-CRI Nichia LED (such as a 519A) to get a clean tint, beautiful color rendering, and better overall runtime
Requirements: No other heavy modifications are needed; I want to preserve the stock driver unless you have a better idea.
Thank you for taking the time to read this.
