new 80W/15A monster zommie light?
check this out… too bad it’s not really budget light, the price range is between $432 - $500+
http://item.taobao.com/item.htm?spm=2013.1.0.153.plK6Yf&scm=1007.77.0.0&id=14230331591&pvid=a6346585-f7a9-43a4-8d3d-4b9145ca75ef&ad_id=&am_id=&cm_id=&pm_id=
flashlight description ( translated by bing)
1, on the basis of the original 2D80 to correct negative electrode conductive capacity, increase conductive to electricity, maximum design currents up to 15A, strongly recommended supporting d lithium (request can offer support), other batteries will have a tremendous impact on output power.( can use 32650 batteries)
2: one of the Center LED, not like MCE or CSM360 more core flashlight no disadvantages of long shots, effects long shots such as U2 increase lamp Cup (maximum dimensions of 78MM*60MM—market form of the XML Cup) effect of long shots (certainly more than other similar products in the small cup), and can take into account flood, in the US, flashlight belonging to distance into account. ( lamp cup = reflector)
3 Professional synchronous rectifier circuit, high efficiency heating small. Magnetron three dimmer, currently up to one of the stalls of the magnetron circuit. Design of zero before shutdown, reset the zero current is 0.
4: high efficiency high brightness, low-cost, compared with the CSM360 value for money than a cut.
5: compatible with multiple batteries, courtesy of classic. Compatible car charger power supply, compatible with mains power supply continuous working.
6: automatic climate control, continuous work, never stopped working at high temperature, as long as you have power. Lithium battery low voltage protection.( no worries about heat)
7 Professional thermal design, near-zero thermal resistance between LED and lamp holders. To work to ensure stability under high power. ( i think it meant it has copper based plate)
8: design of variable focal, to rotate the head spot can be uniform or HD only a week. ( work like a zoomie)
flashlight feature ( translated by Bing)
operating voltage : 6-9V (5XML or 7XML), 6-15V (9XML)
⊙The power : 45W/5xml;60W/7xml;80w/9xml
⊙ The brightness :
Theory of 5xml=4000-4500LM/(the actual test and CSM360 much, since CREE high, plus Center has the illuminant, the effect will be better)
Theory of 7xml=5500-6000LM/(actual tests exceeding CSM360 brightness, because CREE high, plus Center has the illuminant, the effect will be better)
Theory of 9xml=7000-8000LM/(actual tests exceeding CSM360 brightness, brightness equivalent to 1.5 CSM360, calculated according to this CSM360 cost up to 1500—-really earn big, huh, huh,( big WOW) since CREE high, plus Center has the illuminant, the effect will be better ( brighter)
⊙ Size : length 290 mm, diameter: 82 mm, diameter 43 mm, diameter 46 mm tail (tail)
⊙ Use batteries (lithium 9xml recommend the use of 3D, full power output, 5xml or 7xml can be 2D lithium power output)/standard :
4-6-9*18650 lithium-ion batteries lithium-ion batteries or 8-12-18*CR123A or 4-6-9*17650 or 2-3*C (26650) lithium-ion battery or 2-3*D (32650) lithium-ion batteries, used long cylinders (not included) up to 3D when batteries such as lithium or 9*18650.
⊙ Weight (net):1100 g.
Let’s hope this way of placing LED’s will catch on with the cheap manufacturers :slight_smile:
