Hi BLFers,
D25S headlamp is available on Amazon. I helped improve the UI and emitters. It is an upgraded version of D25 headlamp, featuring two SST40 emitters for 1200 lumens and better UI. If you think the quality of D25 is acceptable, D25S will be a better choice.
D25S Kit (Upgraded Version): $25.99, only $19.49 after 25% off code: D25SDEAL (AMAZON US ONLY)
D25 Kit (Old Version): €26.99, only €18.89 after 30% off code: SofirnD25 (AMAZON DE ONLY)
Link to D25S Kit (Upgraded Version): https://www.amazon.com/Headlamp-Rechargeable-Flashlight-Inserted-Upgraded/dp/B07NJ9PCJC
Link to D25 Kit (Old Version): https://www.amazon.de/Sofirn-wiederaufladbare-Kopflampe-Leuchtstufen-Sucheinsätze/dp/B07G83ZTCV
Nice … Just snagged one. Many Thanks
Hi Barry,
Will you be selling the D25S on Amazon DE, too?
What CCT do the SST-40 have? I assume you took 6.500K and not 5.000K, correct?
The UI appears much better than the one D25 uses. :+1: However, I doubt that strobe is often wanted in a headlight (if wanted at all). So, doubleclick for strobe might confuse some people as they expect the light to active turbo instead of strobe/beacon.
Cheers,
Thomas
Wow, if I needed a headlight, I would pick one up.
Looks like a great deal.
SST-40’s are a good upgrade. Not real keen on the 6500K but that can be changed later. Got one, thanks Barry.
How many of us still “need” a headlight? That’s funny.
Barry, what is the size of the mcpcb and is it glued? I would like to mod it with quad e21A in both reflectors. Might buy a few if they are easily moddable.
We will try sending inventory to Amazon DE next batch. The tint is 6500K. Thanks for your suggestion for the UI. I will think about it. But I don’t know if the factory will listen to me again.
@Barry, is it possible to get them to use SST-20 4000k?
You can DIY.
Sofirn makes excellent lights and are very tempting. The things that hold me back are the cool CCT and low CRI.
I know that modding is part the fun, but I travel so much that I rarely have time lately.
So thank you Sofirn for saving me money. :nerd_face:
I am afraid not, different size.
Your US Amazon is sold out. Any chance re-stocked?
give the option neutral white luxeon v
I was able to mod the old version. Mcpcb is glued but was able to pry it out with the help of some heat. Tried with two 219cs on KD 16mm mcpcbs. Had to sand down the sides of mcpcbs so that leds would be close enough to align with the reflectors. It worked, although I settled with reflowed neutral white xml2s on the original mcpcb since I found a couple in my stash. I was also able to fit 17mm Yajiamei optics after sanding them down. Not sure if you can reduce Clemence’s VR16SP4 enough to fit though. Maybe 2x2 on VR16S1 would be easier.
Thanks a lot for listening to BLF’s “voice of the customer”. :beer: :smiley: Actually, this is one of many things I really appreciate about Sofirn.
In my humble opinion the D25(S) host is quite useful. Things I would like to see improved would be:
- different emitters and/or optics for left and right LED, e.g. my favourite configuration: red light (XP-E2 deep red 660nm) and white light (LH351D 4.000K 90CRI) with red light behind a 60° TIR lens and white light in an SMO reflector
- better current/temperature regulation
- more sophisticated UI (e.g. doubleclick button to active/cycle red light, single press on or off, hold button to cycle low-med-high)
  • overhead strap for more stability when attached to one’s head
You could call this one “D25 Pro” :stuck_out_tongue:
NW option please.
Hello, Due to a lack of availability, we will not be able to obtain the following item(s) from your order: “Headlamp, 1200 Lumen Rechargeable Head Flashlight with 18650 Battery (Inserted) for Running Camping Hiking Outdoor, Upgraded Version” We’ve canceled the item(s) and apologize for the inconvenience. If you see a charge for the canceled item, we will refund you within 1-2 business days. If you are still interested in purchasing this item, it may be available from other sellers. Please visit the detail page for this item below: http://www.amazon.com/dp/B07NJ9PCJC If you took advantage of a promotional offer when placing this order, this cancellation may affect your order’s eligibility for that offer. If this is the case, please contact customer service: http://www.amazon.com/contact-us?ref=fxm_em_2_4 Sincerely, Customer Service Department
Shows as in stock??
I will let you know once it is available on Amazon.
I am so sorry for the inconvenience caused to you. D25S headlamp has arrived at Amazon warehouse, but the inventory has not been updated for the time being. The inventory shown now is shipped from China. I’ll let you know if there’s any latest news. Thank you for your understanding!
