New Arrival: RK6018 – Compact Design 60V 18A High Current Power Supply Officially Launches!
New Arrival: RK6006H Buck-Boost 60V 6A Power Supply Output overshoot test
Hello, we make a DIY case for battery input with our RK6006H, it is suitable for Dartek A3 battery socket, if your battery is similar design, you can use it directly, you can contact us for the 3D print file, If you use other battery, the socket may needs to be adjusted
RK6006H: https://www.aliexpress.com/item/1005012537498638.html
Hello, in this video we show how to use the under voltage protection for RK6006H, First, you need to enable UVP option, And you can set the UVP value and delay time, When the input voltage keeps lower than uvp value for delay time, Output will be cut off and show UVP
A customer asked me why there is a 68V in the middle of the screen, Because your input voltage is low and the boost mode is enabled, For example, if you just use 18V input, and you want 60V output, it changes the input voltage to 68V so that you can get 60V output
Hello, for RK6006H power supply, when you disable or enable the boost output function, you need to reboot to make this function effective
New Arrival: RK6006H Buck-Boost 60V 6A Power Supply Efficiency
Promo Price (Limited Time)
RK6006H:$ 3 5 .99USD (normal price from:$ 45.99 USD )
RK6006H-BT:$ 3 8 . 9 9 USD (normal price:$ 48 . 99 USD )
Discount Time: 202 6 . 7 . 28 - 202 6 . 8.3 PT .
Stock: Only 100 units at this price. Once sold out, back to normal price!
Buy Links
RK6018: https://www.aliexpress.com/item/1005012788956404.html
New Arrival: RK6018 60V 18A Power Supply Protection (OVP,OCP,OTP,SCP,UVP)
New Arrival: RK6018 – Efficiency tests under different voltage
New Arrival: RK6018 – Ripple test
New Arrival: RK6018 – Source effect
New Arrival: RK6018 – Dynamic testing
RK6018 is different with other RK power supplies for input output cable connection
Hello, in this video we show the feedback from our customers. They design the case based on RK series power supplies
