New Drivers from intl-outdoor
LD-25 2.6A 3-5Modes Circuit board
Features:
*Suitable for one 18650 or 26650 battery
*Input voltage: 3-4.2V
*Current and Modes:
*High (2.6A) - Medium (1A) - Low (150mA) - Strobe - SOS
*Constant current circuit
*Memory function
*This driver does not use PWM
*PCB Diameter: 17mm
*Total height: 6.25mm
*Gold plated contacts
*Low voltage protection: at 3V the light will step down to low mode and start flashing
*No reverse polarity protection
*Tinned leads
LD-25 2A 3-5Modes Circuit board
Features:
*Current and Modes:
*High (2A) - Medium (1A) - Low (150mA) - Strobe - SOS
*Memory function
*PCB Diameter: 17mm
*Tinned leads
LD-29 2.8A 1/2 Cell Circuit board
Features
*Suitable for 1 or 2*18650 or 26650 batteries
*Input voltage: 3-8.4V
*Current and Modes:
High (2.8A) - Medium (700mA) - Low (100mA) - Strobe - SOS
*Current on High with 1 cell 2.5-2.6A
*Constant current circuit (2 cell only)
*Memory function
*PCB Diameter: 18.5mm
*Contact board diameter: 20.3mm
*Total height: 8.9mm
*Low voltage protection 1 cell: at 3V the light will step down to low mode and start flashing
*Low voltage protection 2 cells: at 5.8V the light will step down to low mode and start flashing
*Reverse polarity protection
*Tinned leads
LD-30 Boost 1/2*AA cell Circuit board
Features:
*Suitable for 1 or 2*AA batteries
*Input current 0.9-3V
*Output current: 650(1AA), 900mA (2AA)
*PCB Diameter: 17mm
*Total height: 8mm
*Cathode brass pill diameter: 5mm
*Modes:
High - Low (10mA)
High - Medium (100mA) - Low (10mA) - Strobe
*Low voltage protection: The light will step down to low mode and start flashing
*Tinned leads
Nice 2AA driver there. Good to see that available.
At last no-PWM drivers that can probably fit P60 pill. Too bad the 2x18650 driver is tos a bit too big for STL-V2… Might have to try to jam it in, though…
Thats what I said to her the other night... ;-)
Well, are these really CC or just high frequency PWM?
I have no idea, maybe wait for someone to test it
These are the step-down regulators, aren't they?
Well I have the LD-29 (inside my XINTD L2), not exactly this one sold at IOS, and I used my multimeter and there is no frequency to be measured. I can definitely measure 4700Hz on some older Nanjg105C from Kaidomain.
As far as I have read on the Chinese forum, the VG20 used the some lower current LD-29 too. So those owning these two lights can really do some testing of the PWM.
Hehehehehe
Is it possible to use only the top PCB board to make it fit in a P60 drop-in?
