Hello everyone!
Because of the success of the X60L, we decided to start a new production run, and upgrade them to XM-L2’s!
We currently have a limited number of X60L’s made with Cree XM-L2 U2 Cool White, and T6 Neutral White emitters!
These models are 15% brighter than 1st gen XM-L emitter X60L’s!
The P60 Drop-in module is designed for SureFire C, P, Z series, and also fits some Solarforce models (but will require the use of the included spring or copper / aluminum tape).
These are very solid, well built drop in modules! They provide a good balance between long runtime and high output, while avoiding the pitfalls of some of the more dangerous over-driven drop-ins out there. They provide a perfect beam pattern and have a good balance between spill and throw! Each drop-in is fully tested prior to shipping, and out of the first production run have had zero warranty issues with these units, which goes to show how well these are made! Buy with confidence. 8) Your P60 hosts will thank you. ![]()
Introducing these to the market at only $44.99!
But for a limited time, use the coupon code: X60LXML2 at checkout for 10% off!
Specs:
• Powered by Cree XM-L2
• Modes: 3 Mode (High, Medium, Low)
• Current: 1.5A +/- 100mA
• ~530 OTF Lumens (CW U2)
• Input Voltage: 3-6v
• Supported Cells: 1x18650/17670 Li-ion cells or 2x CR123 Primary Lithium cells. Do NOT use 2x RCR123/16340 Cells.
• Size 29mm (40mm with spring), Weight: 20g (0.7oz)
• Compatible with: SureFire P, C, Z
Features:
• All aluminum for better heat transfer (compared to brass).
• The first uni body constructed P60 drop-in module (with the reflector, and heatsink machined from one solid piece of aluminum).
• Precision machined aluminum OP (orange peel) reflector.
• Reverse polarity input protection
• Over discharge protection ~2.75v (Only applies to High and Medium modes)
• Gold plated spring
• Linear Current regulated. No PWM.
• Thermally potted driver
Here are a few pictures:
Check out the spec sheet for more info.
X60L 3-mode Cool White U2 Cree XM-L2 P60 Drop in
X60L 3-mode Neutral White T6 Cree XM-L2 P60 Drop in
