I am not that big of a fan of headlamps but I still use one almost every day so, they are handy for sure.
For a nice deal with a nice price go here -> https://budgetlightforum.com/t/-/35665
Nitecore HC30:
Max Output -> 1000 lumens
Max Beam Distance -> 162 m
Max Beam Intensity -> 6600 cd
Max Run time -> 330 h 0 m / 13.75 d
LED -> CREE XM-L2 U2
Reflector -> SMO
Battery -> 1 × 18650, 2 × CR123
Special Modes -> Location Beacon, SOS, Strobe
Length -> 98 mm / 3.86 in
Head Size -> 24.2 mm / 0.95 in
Weight: 40.3 g / 1.42 oz
More info ->-> http://flashlight.nitecore.com/product/hc30
The on-paper specs suggest a very similar beam to that of the H3 Warboy (same max lumens, peak intensity numbers within 10% of each other, similar throw distances). Peak intensity numbers suggest the HC30 has a slightly hotter hotspot. Given that overall max lumens are equal, I presume that means that the HC30’s spill is slightly less than the H3’s at a given output level.
1k lumens from 1x18650 cell has become so boring. Its been like what….2 years since this was achieved and barely any manufacturer has stepped up their games…
Those 1k lumens flashlights is so common even the cheapest of them can achieve them. I’m not talking about quality, features etc here, only lumens…
Well, believe me, at 1000 lumens, it gets too hot. Even the nitecore hc50 at 565 lumens gets very hot after a few minutes. Also, not everyone needs 5000lumens and 1000m throw, in fact, very few do.
If you want more than 1000lm out of a 1x18650 flashlight, you need multiple leds. The BLF-A6 gets to 1600 lumen, but at a severe cost: lots of inefficiency at turbo, so extra power and heat with not much extra light, you don't want that on your forehead.
A triple led headlamp would be something new and could reach 2000 lumen. Not sure if that would be so great as a headlamp, but people will buy it I guess.
