New LED Headlamp with Red Light 1000 Lumen 230° Wide Beam 10 Lighting Modes
Do you need a headlamp that offers ‘you see me’ or even brighter, ‘I see you’ lighting? Bike riders use those terms for bike lights. The HAOYISHU Headlamp Flashlight is a headlamp that does both. It offers daytime brightness if you need it. The light has 10 steady and flashing modes and sells for under twenty bucks.
Hardware specs
1200 lumen main front LED
1200mAh rechargeable lithium-ion battery
4-8 hour run time depending on mode
Main front LED adjustable angle
IPX4 rated (protects from splashing water)
Weight: 4.4 oz
Design and features
10 lighting modes
230 degree light beam
90 degree adjustment on main front LED module
Blue LEDs on battery module indicate charge progress and power remaining
Modes:
Main front bright white spotlight
White front ‘strip’ LEDs, spotlight off
All bright white front lights
Lower beam all front white lights
All front white lights flashing, bright mode
Steady front red strip LEDs
Flashing red front strip LEDs
Rear red LEDs on steady
Rear white LEDs on steady
Alternating red and white rear LEDs flashing
The HAOYISHU Headlamp is a versatile task or safety headlamp. Its variety of lighting modes and brightness levels, plus the rear-facing safety LEDs make it a great choice for work, recreation, or both.
Learn more: HAOYISHU Headlamp Flashlight review - ‘Looking forward’ to daytime brightness - The Gadgeteer
Official Amazon.USAmazon.com
