Hello BLF folks,
Wurkkos TS15 is the upgraded version of TS12, and it will available on next week.
The post is only for Wurkkos TS15 mini thrower.
TS15 is the upgraded version of TS12 (we take the beam shot video here). The Max Output is 900 lumens (on double clicks the button to turbo), and turbo mode will continue 2 minutes, then stepdown reduces the brightness to 350 lumens with 1 hour.
↓↓The high mode runtime by 14500 Li-ion battery
↓↓The medium mode runtime by 14500 Li-ion battery
↓↓The low mode runtime by 14500 Li-ion battery
The Wurkkos TS15 is operated by side e-switch Hold the button could control main light with 5 levels output:Moon-low-medium-high-turbo.
4 clicks the button when turn off will get lockout/unlock mode immediately, or you can unscrew the body and interrupt the electrical contact. Also, it’s powered by included 900mAh 14500 Li-ion rechargeable battery (or AA battery we take the video here). The charger for max 5V/1A USB-C port.
It also include ATR Advanced Thermal Regulation, that kicks in at 50°C and reduces the output to cool the light.
Wurkkos TS15 mini thrower Specs:
Emitters: LUMINUS SFT25R 6000-6500K
Operating voltage: 1.2V-4.2V
Beam Angle: Center 8°; Flood 72°
Battery: 14500 Li-ion battery or AA
Dimensions: 91.6 mm long, head is 29mm
Weight: 51g ( without battery)
Reflector: Smooth Metal Reflector
Flashlight body: Aerospace grade 6061 aluminum alloy, HA-III hard anodised coating, matt finish
Water resistance i.a.w. IP68
Reverse polarity protection to protect against improper battery installation.
Advanced Temperature Regulation (ATR) technology, stepdown at 50°C
In the post, I have only given a preliminary introduction to this product, after continue to update as planned.
If you have other interest parameters just live your comment here.
