new products RD6018P, RD6018P-Set, RD6018P-Max set 5-Digit Display 60V 18A power supply available now
Hello, my friend, RD6018P 5-digit 60V 18A 1080W power supply is coming
Hope you like RD6018P and you can check the product information and make order in this link: RD RD6018P 60V 18A 5 Digit Display DC Adjustable Step Down Voltage Regulated Power Supply Buck Converter Laptop Repair&1200W PSU - AliExpress 1420
There is also RD6018P complete set and RD6018P-Max complete set available, the price is also lowest price!
RD6018P set: RD RD6018P Completed Set 60V 18A 1080W AC to DC Digital Adjustable Lab Bench Power Supply for Repair - AliExpress 1420
RD6018P-Max set: RD RD6018P-Max 60V 18A 1080W Completed Set 5 digit AC to DC Laptop Mobile Phone Repair Regulated Power Supply - AliExpress 1420
As what we do all the time, we will set the lowest price when new product is released, so here is the price:
RD6018P:$ 72 .99USD (normal price:$ 105 USD )
RD6018P-W:$ 76.99 USD (normal price:$ 113 USD
Discount Time: 202 5 . 7.11 -202 5 . 7 . 17 P S T .
It is much cheaper than other RD power supply now!
Russia customer can choose Ozon to make the order:
Покупатель из России может выбрать Ozon для оформления заказа:
RD6018P: https://ozon.ru/product/2442590274
RD6018P 220V EU plug set: https://ozon.ru/product/2440370609
RD6018P-Max 220V EU plug set: https://ozon.ru/product/2440873731
Attention: we just prepare 100 PCS for this special price and we will return to normal price if all the stock sold out.
We also prepare the S800 case and input 1200W 68V PSU in the RD6018P link, you can choose them if you need. 1200W PSU can let RD6018P output 60V 18A when you use 220V AC input , under 110V AC input, it can let RD6018P output 950W max.
Here are some important features about RD6018P:
·Support 60V 18A 1080W maximum output
·Low ripple: 20mV
·High efficiency: full output efficiency >95%
·5-Digit display
·Support multiple display styles and custom color
·Support PC software control with USB cable connection
·Support Android Phone RIDEN APP control via WiFi(needs to order RD6018P-W version, for now only Android APP, no IOS APP, complete set has no WiFi board)
RD6018P Technical Parameter
Input voltage range: 7-70.000V
Output voltage range: 0-60.000V
Output current range: 0-18.000A
Output power range: 0-1080W
Output voltage resolution: 1mV
Output current: 1mA
Output voltage accuracy:0.05%+4mV
Output current accuracy:0.1%+6mA
Default cutoff current value when charging: 10mA
Output ripple typical: 20mV
Working temperature range: -10℃~40℃
External sensor Temperature detection range:-10℃~100℃/0℉~200℉
External sensor Temperature detection accuracy:±3℃/±6℉
Constant voltage mode response time: 200us@0.5A-18A
Constant voltage mode load regulation: ±(0.1%+0.2mV)
Constant current mode load regulation: 0.1%+3mA
Capacity measurement range: 0-9999.99Ah
Energy measurement range: 0-9999.99Wh
Capacity and energy statistical error: ±2%
Buck working mode: (input voltage÷1.1)-2
Over temperature protection: System temperature>80℃
Screen brightness setting: 0-5(6 level in total)
Screen: 2.4 inch color HD display
Weight(with package):About 0.74kg
Product dimension: 1678169mm
Cooling fan start condition: Output current>6A or System temperature>45℃
Cooling fan shut down condition:Output current <5.9A and System temperature <40℃
new product coming
do not miss the lowest price chance if you need it
Can you maybe show the inside of your 1500W 68V Power Supply?
And for your Max-PSUs - so I still need to switch it on on the backside or is the switch in the front good for that as well?
If not, it would be so nice to have the main power switch on the front.
You want to see more about 1500w psu ?
you want to switch 110V or 220V input? if so you need to open the case and find the red swtich on the side of the 1500W PSU, normally the input AC volage you use is fixed, so that you just order the correct version and it is ok, and for RD6018P, it use 1200W PSU inside not 1500W PSU
New product RD6018P 5 digit 60V 18A real test: over high input voltage, reverse input
New Product RD6018P output short circuit protection, no damage for the device
this sale will last to 20th, end at Monday, please notice that, if you need it, you can take one with lowest price
RD6018P:$72.99USD (normal price:$105USD)
RD6018P-W:$76.99USD (normal price:$113USD)
Aliexpress
RD6018P:
RD6018P set:
RD6018P-Max set:
Ozon
RD6018P stable output voltage when input voltage changes
New RD6018P-Max released: actual ripple test, low to 10mV, technical parameter 20mV VPP
New Product RD6018P-Max short output, no damage for the device
if you find your RD-Max power supply display rotates 180 degrees, normally you hold on the button 5 or 6 and power on it again, the display will rotate 180 degree.
RD6018P-Max set
Aliexpress: https://vi.aliexpress.com/item/1005009455962713.html
Ozon: https://ozon.ru/product/2440873731
hello, some customers ask us if Max version power supplies are better performance, actually there is no performance difference, only bigger screen, silicone sleeve and USB-C port, no other differences
Would you agree to send the Youtube Channel “EEVBlog” one of your new power supplies for him to test it?
I sent it before , but the package was not picked up , it was returned. EEVblog don’t like our products
some customers find that when connect device to PC, the PC software cannot work, actually you just go to the device management, if there is not a port called CH340 updated, the cable has no communication, we cut a good cable and a bad cable to check inside, bad cable only has 2 thin cables for delivering power
hello, some customers find the output does not equal to what they set, actually the output mode is decided by voltage current you set, and load resistance, CV mode, I=U/R, CC mode, U=I*R.
Maybe it was a problem delivering it to the PO box:
For couriers like Fedex, UPS etc that CAN’T deliver to PO Boxes, please email me for an address
https://www.eevblog.com/about/contact/
I’d also be interested in an independent review.
I want too , but they don’t
