· Anodized AI-Alloy Construction
· GFC (Gamble Free Concept) Impact-Resistant System
· CREE XP-G2 (Cool White - CW, 6500-6700k), Max (OTF) 140 Lumens, Max 150hrs
· Normal Output: Low (40lms/6hrs), Ultra Low (1.2lms/150hrs), High (140lm/1.3hr)
· High Quality toughened mineral-glass lens, precision polish for impact resistant, both side AR-coated
· Powered by 1x / 2x AA size battery (Alkaline,Ni-Cd,Ni-MH)
· Built-in battery inverted-load protection.
· 10 meters dunk resistance
XTAR VP4 Intelligent LCD AC/12v 18650 26650 Charger
The charger is compatible with 10440/16340/14500/14650/17670/18350/18490/18500/18650/18700 and/or two 22650/25500/26650 lithium batteries
Features:
- Compatible with IMR lithium battery
- Each channel is independent
- Three-stage charge algorithm(TC-CC-CV)
- Three charge current options (0.25 A, 0.5 A, and 1.0 A)
- Soft-start function, to avoid damage from large charge current while charging.
- Automatically cut off when the battery is charged fully
- Precision cut-off voltage at 4.2V
- Compatible with small capacity battery
- Over heat protection
- LCD displays each battery real time statues
- Use high power intelligent step-down DC - DC circuit, greatly reduce the energy loss;
- Built-in reverse-polarity and short-circuit protection circuit
- Use fireproof material for the shell
- 0V activation function can wake up the over-discharged/sleeping batteries
- 120°angle high definition VA screen to display the charging current ,voltage and power indicator, you can see the charging status from any angle of view.
- Certified by CE, RoHS
