Here's some progress! I've been really busy and hadn't had much time to work on it, but here's the latest. By the way, if they had an Olympic sport for the one who most anxiously watches paint drying, think I'd get the gold medal! I did some work on the reflector...fit everything together so it fits flush and snug. Then re focused everything.
Now the fun part, polishing and smoothing the part the reflector cup sits on. This took a couple hours, but I think it turned out okay.
More polishing...
Done!
Next is painting the top half of the reflector.
Next is bonding the reflector cup to the mount that will hold it inside the two halves of the host body.
The mount is the remnant of the original reflector I cut down to get the xhp70.2 to work, but that was a fail. I had to plan this out carefully since I had originally planned on using screws, but decided it would be too much hassle. It has to hold the whole weight of the reflector, heatsink driver and emitter so I needed it to fit right and be flush. That process was crazy difficult and tedious, but I think I got it close enough.
I'm impatient so I used the superglue and sodium bicarbonate (baking soda) trick. For those who don't know, if you mix baking soda and cyanoacrylate (superglue), it makes a chemical reaction that generates heat, a bad smell, and turns your baking soda into a sort of concrete, almost like epoxy, in seconds. I got a strong bond so I know it's not going anywhere!
Here's the look from the top. I painted the reflective party since it was all scratched up. The reflector opening is taped off since I painted the reflector assembly after gluing.
Up next: mounting the finished heatsink assembly to the reflector, getting it inside the host, planning out the electrical connections, mounting the battery, and hopefully getting done light out of it!
