【New release】Meet the strongest lumen CYANSKY P50R 12000 lumens
CYANSKY has launched a high-brightness and reliable flashlight ----- P50R, under the public’s attention.
The CYANSKY P50R flashlight, with its astonishing 12000-lumen flow and great features, will be an excellent choice.
With its amazing 12000-lumen flow, the CYANSKY P50R flashlight gives you a bright lighting experience like never before. At the same time, it is equipped with 4 Cree XHP50.3 lamp beads. The irradiation distance is wider, and the maximum irradiation distance reaches 328 meters.
(Thanks to FLASHAHOLIC for the picture display)
In addition to the amazing lumen output, the CYANSKY P50R flashlight also provides multiple lighting modes to meet the needs of different environments. The one-button control is easy to use, and you can choose the appropriate mode according to the actual situation.
Equipped with TYPE-C charging on the body, there is no need to worry about the sudden flashlight running out of power during long-term outdoor activities. Whether on a rainy night or a rugged mountain road, it can consistently provide reliable lighting.
Despite its powerful lighting capabilities, the CYANSKY P50R has a compact design for easy portability. Whether you put it in a backpack or pocket or attach it to your belt, it doesn’t take up much space and is a great addition to your outdoor gear.
Tip:
It is recommended to use a CYANSKY 2140P power lithium battery to power P50R to achieve the best performance of the product. The output performance of the torch may vary with other 21700 lithium batteries.
If the measurements in The Flashaholics review are accurate, then it’s really impressive! Good to see that it is able to reach its claimed lumens on turbo. The throw is apparently also (way) more than what is stated in the specs, which is a good thing for my taste/preference!
I also noticed in his review that it has the CREE XHP50.3 HI (so the domeless version), which also might help to explain the good throw of the flashlight. (In your own marketing you only mention that it is a XHP50.3, so I expected it to be the regular XHP50.3 with a (silicone) dome.)
Certainly an impressive flashlight, especially for a single 21700 flashlight!
Nice always to have new models… No doubt. This one IS a beast lumens one
Very interesting light! Would be nice if it uses XHP50.3 HI 95CRI emitters.
