Interesting design. If it’s made as well at the L2P L2T models then the cost is very reasonable for the quality. Since it’s P60 compatible I’ll guess that the bezel and tailcap will fit any other L2 model. If so the D tailcap would make a very trim twisty. The bezel is so different looking it really doesn’t fit the previous models but a matching L2 or 2P bezel would look good on the 2D.
One other thought. Looking at the pics and comparing model specs, is the body switch assembly removable? The stock 2L models are 140 mm long, the 2D is 148 mm. I’m curious to read once some members get a few if someone can determine if the switch is removable.
I'd have to assume it's a mechanical switch, since they are saying it takes standard pills. Looks like they made the switch lower positioned so not to interfere much with a wrapping.
Similar to my XP-11 from WB, mod'ed of course: about $24 total part/light for about 1,100 lumens in a small side switch, nice quality pocket light, with a great UI. This L2D will be longer though, but higher quality body for sure, plus with interchangeable pills.
I really like side clicky lights, so I’m ordering one of these.
Can anyone point me toward a neutral/warm emitter drop in for single cell use with a bright, very floody output?
