New to modding and need help on which driver to use
Ok I am new to modding and need some advice on what driver to use in a build. I got an olight m3xs for free because the stock driver is dead. I am not going to use the side switch just the tail switch. I am using a Luminus SST-40 N4 6500K LED on Copper DTP MCPCB and two Sanyo 18650 3500mah 3.7v cells. The driver needs to be 30mm I just don’t have enough knowledge yet to figure out the best driver to use. Any and all info is greatly appreciated thanks.
Welcome to BLF. Your username also describes your light build, I like it.
your problem is going to be using a 3V emitter in a 7.4V battery configuration.
If you go with a 6V LED like the XHP 70.2 I would say to follow most any Convoy L6 (30mm driver also) mod builds and you could probably keep the side SW.
I am not familiar with what Buck driver you would need to use the 3V SST40.
I already removed the side switch this is a learning exsperance build anyway lol.
ok so after doing some reading and learning i decided to go with an XHP70.2 6v led and a 30mm FET + 7135 Driver - MTN-30DDm - 2S-4S Input Voltage (Clicky) driver. I am hoping this combo will make a nice thrower out of this host thanks vwpieces for the info and suggestions.
