New to Modding - Looking for Some Tips
I’ve recently been bitten by the flashlight bug again and this go round I’ve been obsessed with the thought of modifying a few Maglites just cause I can. I realize there are a lot of host options out there and Maglites are a bit antiquated these days, but it’s as much for sentimentality as anything.
So, I started reading a bit here and looking over at Kaidomain for parts and I’m getting a bit overwhelmed between LED choices and trying to find a suitable driver. That being said, here’s a run down of my first mod goals:
Mod 1)
Maglite 2D (Older LED Model with Mechanical Switch)
- Aiming for ~ 1000 to 1500 lumens at 50 to 65k cd (Would love more light, depending on other considerations)
  • Must be able to maintain regulated output for 3+ hours. (Light output is dependent on meeting this)
  • Must use NiMH / Alkaline cells.
  • Single Mode (I have an idea for running two modes, but I’ll bring that up later)
The purpose of this light would be to be used as a search light / area check light during extended power outages / looking along river banks or fields for long times. Endurance is the key at a solid light level as I can be out there for a long time. One of the older Olight SR series lights was one my list for this because it was close to these stats for several hours, I just never pulled the trigger. I know I need a boost driver, mounting plate for the LED to sit on, a heatsink for the whole thing, and quality NiMH. So far I’m looking at either an XHP 35.2, XML2, XPL2, or maybe SST40. I know the XHP is a 12v chip, but I’m just looking at options.
That’s kind of where my starting point is, I’m just trying to narrow it down from there.
I don’t think this is possible. You will have problems with the heat and not enough battery capacity.
you wont do it with D cells, but you Could fit an AWT IMR26650 in there, make sure your driver has LVP built in though.
I figured capacity might be an issue, I was hoping newer LEDs had enough lumens per Watt to comfortably sit at 1000 on 2 to 3 amps drawn from the cells.
Im surprised that heat might be an issue. I figured for a light that size with a nice heat sink would be fine thermally.
I know I could do crazy things with some nice 26650s, I’ll save that for later down the road though.
2D Maglites pose some interesting problems. Although they’re physically large, the way they’re constructed it’s not conducive to an LED type setup.
Your first problem will be sticking with NiMH/Alkaline batteries. If you stay with that choice, you’ll have to put in a boost driver of some sort somewhere in the head.
The easier way around this is (as mentioned earlier) is to use 2x26650’s, which will essentially convert your 2D into a 6D electrically. It may seem counter intuitive, but finding a buck LED drop in is a lot easier. If you go this route Adventure Sport Flashlights has some pretty cool conversion kits to get it all done. PVC sleeves that’ll make the batteries fit perfectly and work well.
As for the emitter itself, ASF sells those as well, some get a bit pricy but I believe the quality is good.
There used to be a company called TerraLUX that made a triple LED drop in conversion for 6D Maglites (essentially what you have if you do a 26650 conversion), but I believe they stopped making them. Part was called the TerraLUX TLE-310M-EX. It’s quite bright for what it is and I’d argue that it easily puts out 1k lumens on 2x26650’s.
It’s possible. Notice OP said he wanted the light to maintain solid regulated output for 3 hours. He didn’t say it had to maintain 1000+ lumens for that long.
A 2-D sized host should be big enough to maintain solid output for that long. That’s big enough to fit a 21700.
However…. this doesn’t sound like an easy straightforward mod. You might need to fabricate custom parts for the LED, heatsink, driver, and battery carrier.
  • Doable? … Probably. But this would likely be an advanced mod.
  • For a first time modder new to modding? … Not recommended. Might be better to start with something a lot easier and then work your way up.
Anything is possible if you have the time, ambition/drive, knowledge and money. I keep telling myself that everytime I hack a crappy plastic flashlight and mod it to 5000 lm, but it gets old after 4 months of mindless fabricobbling waiting for parts, things breaking, catching fire, parts don’t fit, delays, life happens, run out of money, etc. I almost attempted this, but gave up once I discovered the amount of work it takes.
Best bet for this is getting one of Matt Smith’s (Adventure sport flashlight) D cell Maglite drop-ins. Maglite drop-ins You’ll need lithium cells for best results. They aren’t cheap, but will probably look pretty attractive. If you want to do it cheaper, pop pver to Simon’s Convoy store and grab a C8+ with sst40 for like $25.
