was on ali and saw this light and is this a new trustfire TR3t6?
http://www.aliexpress.com/item/TrustFire-TR-3T6-CREE-XM-L-3-T6-5-Mode-3800LM-18650-or-26650-LED-Flashlight/32295141707.html
I ordered what appears to be the same light from GearBest a couple of weeks ago, still waiting for it to show up.
Listed as a P5 for $15.47:
http://www.gearbest.com/led-flashlights/pp_71050.html
I can't get the Aliexpress link to open from here, but those sure don't look like XM-L emitters to me...
I was thinking the same thing. I checked trustfire’s website and could not find it at all.
The leds are XP-E .
No one has gotten one apart that I am aware of, Have had this light for over a year.
Hard to explain, but the way the reflectors are in there it wants to turn the emitter and wires.
Anyway, construction/build is thin azz metal, the XP-E’s are OK but under driven.
Light is worth the asking price and nothing more.
One other thing, the switch blinks when off, however you can turn that function off by holding down the switch for a few seconds.
Whenever changing batteries it will default back to beacon switch mode.
HTH
Keith
Beacon switch? That's actually kinda cool...
Can't get it apart? Sounds like a challenge to me... Especially since I bought it intending for it to be a triple host for my own build...
you should upload some images.
Not much to show being that it is not dis assembled.
I just got it out and tested amp draw, getting 2.48 on high with a Samsung 2600 battery. Please note that I did braid the driver spring.
It appears that the driver is held in by a press fit aluminum ring. I did not want to trash the light trying to get that out.
After that is out, I guess that is how you get to unwire/remove the reflectors. There are no bezels, the reflector cups are one piece.
It is not that bad of a light but it is one of those drivers where you have to cycle through all the modes to get it to shut off and of course no memory.
Never tried the charging system as I do not trust any of the internal chargers.
Anyway look forward to seeing it apart after someone sacrifices it.
Thanks,
Keith
Look for a thread on this once I get mine in. Passed through Amsterdam three days ago... just waiting for it to hit the US.
please do, i want to see a tear down of this keltex
I actually able to remove the bezel to the light and the same time it cut off the thin cable that they’re using |(
But i’m not able to remove the driver without breaking it
I have posted a teardown/review of this light as purchased from Gearbest here:
