Newbie 1st post, Panasonic NCR 18650B 3400mAh
I purchased 8 of these for my new SkyRay King, the button top is bellow the insulation and will not make contact any suggestions would be greatly appreciated
you have flat-top batteries. Sky Ray King requires button tops.
you can use small, flat magnets or put a solder blob on top.
They were listed as button top, I thought about the solder blob, thanks for taking the time to answer my post, appreciate it.
Steve
I don’t know if magnets would work. As you tighten the head the magnets might slide off, or even start pushing up against the protective covering on top. And if you’re really unlucky I think it might even be possible to short the battery. I’d never use magnets if there’s a possibility it could change the position I initially inserted them in. I wouldn’t want them to make contact where they shouldn’t on the driver.
