Newbie question about moli 18650 cells.
Newbie here. I’ve been lurking here for a while and finally decided to buy some 18650 cells and a i2 charger. Anyway to the question. I recovered some old cells from a laptop battery pack inside I found lime green 18650’s labeled MOLI FSPE.70043.0616 04 ICR-18650H Made in Canada. I tested them using a multimeter and all had voltage ranging from 2.35 - 2.54. I’ve seen to toss anything below 3 volts. Ive done some research and haven’t found much information regarding these particular cell. I did see on an RC forum that these have an operating voltage from 4.2 to 2.5 volts. Kinda made the think they might be worth trying to charge. Any input or information?
Could be OK. Well worth trying to charge and test using usual cautions.
I would give them a try if it was me. Just keep a rely close eye on them and test them along the way. Test them again after resting and see how fast they lose a charge. If they are drained back way down the next day without using them. They shouldn’t be used. Some drain is fine but they shouldn’t lose most of their charge overnight.
Moli makes some really good cells, I do know that.
Will it be safe to charge these on the nitecore I2? If the risk outweighs the reward ill just leave them be. I’ve got several other cells that should good.
I really don’t see why not. They are not terribly low. Just keep an eye on them. Check them by hand to see if they are getting hot while you charge. If they get hot then dispose of them. It’s not likely at all that you will have any problems. They will either charge up and keep a charge or they won’t. If they don’t keep most of their charge by tomorrow then they are not worth keeping.
