Hi
I am the happy owner of a Mastfiff M2 infrared illuminator (AKA ultrafire UF-800)
I say ‘happy’, because 940NM flashlights/illuminators are usually VERY expensive (100$ or more) and P6 drop-ins are usually too floody. So, finally finding a cheap (25:money_mouth_face: 940NM thrower flashlight, was awesome (my second generation monocular really thanked me).
The bad things came out when I tried to run the IR illuminator with two 16340: despite tecnical specs, the led eploded.
Seller gave me his apologies, and sent me two new bulbs: an infrared replacement (for free) and an XML one (that I paid). He also told me that those bulbs could SURELY work with two 16340.
Again, I tried one bulb (the xml one) with two 16340, and again it exploded.
He gave me my money back and I stayed with my infrared bulb.
Case closed.
Now I have a dead bulb (led+driver+metal base assembly) that I want to repair with something that will work fine with one 18650 (no more 2x16340 for ever!).
The mastiff metal ‘led+driver’ base is screwed inside the body and is really similar to the one of a common C8 flashlight, but is REALLY longer.
It’s a 3 centimeters long metal-cilinder, with the led on one side and the circuit+spring on the other. This cilinder has cooling fins, and since the flashlight head also is bigger than the one of a C8, I want to use all of this coolers.
So the question is………………. (please consider I am a REALLY newbie)
Can I mount this led+circuit assembly?
LED
DRIVER:
http://www.ebay.com/itm/121301303007?\_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
