I could not find anything about their die size to compare them with the usual Crees.
219C may be 1.6x1.6 mm, but I can’t even find the source of that again…
Thanks for any info,
TBone
TBone
I have a feeling the NVSx219C’s die is a little bit bigger than the NVSx219B-V1. Just by comparing the beams of similar lights with both of these emitters in them. Not sure though, could be variations in focus finetuning or height of optics or variations in the optics themselves.
Note that there are NCSx219A/B/B-V1 with die sizes comparable to the XP-E2’s. No such thing for the 219C.
B and C Nichia are Cree XP size, or 3.5mmX3.5mm
That’s called the footprint, not the emitter area. The emitter area is what produces the light.
Die is the thingy that produces light, also known as the emitter ![]()
The die size of the 219C is exact the same as XP-G2, and perhaps the 219A and 219B have also that die size?
Here’s an ugly picture (from the 219C test thread) of a dedomed/damaged 219C compared to a dedomed XP-G2 showing that.
here is a crappy pic of a B dedomed from a S41 failure
Eyeball with a caliper under a magnifier is 1.6-1.7mm
Feel free to integrate to the above comparison if you can/wish to.
Ok, well it’s to be expected that these two have similar die sizes, since according to Nichia’s nomenclature the second letter in NVSx219… stands for die size, if I remember that correct (EDIT: no, I don’t ). I just feel they make slightly different beams in my triple EE X6’s. But as I mentioned that could have had various reasons. But even if there were slight differences in directivitiy between the NVSx219B-V1 and NVSx219C for example, wouldn’t necessarily mean it’s the die size that causes the difference, could have a slighty different dome as well. So that basically proves that my first post was a bit stupid.
EDIT: The second letter stands for “chip type”, not for it’s size actually, NVSx319 definitely has a different die size compared to NVSx219C. Sorry.
Thanks. On Djozz’ photo the footprint is 589 pixel (3.5x3.5 mm) and the die is 255 pixel. So the die size of the 219C would be 1.5x1.5 mm.
The footprint of the XP-G2 is only 3.45x3.45 mm (588 pixel) so the die is smaller, 1.45x1.45 mm (249 pixel).
From vwpieces’ photo I get 1.55 mm for the 219B but the resolution is a bit low.
you shouldnt mess all 219b.
NVSW, NVSL have 1.5x1.5mm die
NCSW have 1.1x1.1mm die
So 219b is not 219b? Impressively clever marketing by Nichia.
Good to know.
