Nichia 219C vs Cree XP-G2 S2 - Not understanding my results
Hi guys, I have 2 identical hosts using the exact same driver (Qlite with 12 7135 chips). One has a Nichia 219C and pulls 4.2A and the other has a XP-G2 S2 that can only manage 2.9A. However for some reason the XP-G2 S2 is noticeably brighter.
How could this be? Just to make sure that something wasn’t wrong with the Nichia, and also tried another one. The Nichia LEDs easily pulls the amps but just don’t seem at bright as my XP-G2.
Looking at Dozz’s results, with the difference in amp draw, the 219C should be noticeably brighter. I don’t understand my results.
I don't know what is going on, I can only speculate.
What my tests hardly show is the amount of output drop when the led heats up; my rig is so well cooled that the leds warm up nowhere near to what happens inside a flashlight. So it could be that the 219C is particularly sensitive to output drop by increasing die temperature. (This is not the same as thermal resistance, which is known, it is how the die reacts on the temperature which is there).
Are your hosts well heatsinked or are the leds getting nice and hot in there?
Hi Dozz, thank you for your input!
They emitters are on Noctigons, however the hosts have hollow pills. I’m not sure if heat is the issue though because the light with the XP-G2 is brighter right at start up.
That rules out my hypothesis then, in the first seconds only the thermal resistance of the led itself plus perhaps the ledboard a bit, influences the die temperature.
Is it possible that the hotspot is brighter on the XP-G2, but lumens is higher on the Nichia with a larger but less bright hotspot? The XP-G2 is smaller, so it should result in a tighter beam than the Nichia, some new people don’t know that brighter hotspot doesn’t mean more lumens. (I have no idea how skilled/familiar you are, I’m just making a general statement)
Hi KKW, no these are in zoomies. In flood mode, the XP-G2 is brighter.
Thanks for specifying, in that case I’m at a loss, the Nichia should be about 2x the lumens at the current levels you’re measuring. I’m assuming both are on DTP MCPCB’s?
Yes both are on 20mm Noctigons. I’m at a loss to.
I bought several Nichia 219Cs and in general have not been blown away with their output.
I’m obviously new to led’s and stuff. :stuck_out_tongue:
But, are you measuring the current flow to the led or the current flow to the driver?
Is it possible that a faulty driver would still function but at very low efficiency where the output current to the led is much than what the driver is pulling?
Swap the driver’s around?
You could have a low level short. You could test by disconnecting the LED leads from the driver and then testing for continuity between each Lead and the pill/host. This won't detect a short in the driver though.
Hi Andrew, I’m measuring current at the tailcap.
Thanks ImA4Wheelr. That’s a bit over my head. Perhaps I will just swap the driver out with an identical one and see what happens. Thanks again everyone!
Perhaps you can give me a second chance. If you have a short (one with some resistance) after after the linear regulators (the 7135's), current will flow throw both the LED and through the short. You will get a tail cap reading that is at the max of the regulators capacity (12 x 350ma = 4.2 amps), but the LED itself will only be getting a portion of that current. If you see no obvious shorts (solder filament bridging 2 components, etc), the likely location for a short will be under the LED caused by faulty reflowing of the LED to the MCPCB (aka star, base).
I've had this happen several times. It sometimes occurs when the LED is pressed down during the reflow.
The way to test for continuity is to set your DMM to measure resistance (Ohms, the upside-down horseshoe symbol). When you don't have the probes touching each other, the meter usually doesn't display anything. When the probes are touched to something that conducts electricity, a number will appear which represents how much electrical resistance exists between the probes. When you touch a probe to either of the LED's Leads (wire connecting LED to the Driver) and the other probe to the pill, there should be nothing displayed as there should be no conductivity.
I hope this helps. This is an important concept to learn if you want to mod lights. If the above isn't clear, please say so. Hopefully, someone better at explaining things will hopefully help clarify.
That was SUPER helpful and clear. Thank you so much for time & energy explaining that to me!
De nada. Thank you for the feed back.
I should have also said that a short like I describe is unlikely as most shorts usually have very low resistance and end up just completely bypassing the LED. But, it's a good idea to do the test I describe every time you build a light. It only takes a couple seconds to do and can catch a potentially dangerous situation if the short is between the positive pad and the host body.
Best of luck getting that 219 to sing like it was meant to do.
