I learned something tonight that really surprised me and makes me aware of some things I should have done over two years ago.
I have been working on the Nichia 219, with a direct to copper center pad. Tonight I set up a testing station with a 2.8A NANJG 105c driver, a Judco switch and my analog ammeter in-line, for taking amp readings.
The results were scary and surprising.
I found that Chinese (or cheaply made) battery holders are not just bad, they are useless!
3AA Eneloops in a Chinese battery holder - 1 amp on high (tested more than one new holder, all were the same).
4AA Eneloops in a Chinese battery holder - 1.25 amps on high (tested more than one new holder, all were the same).
That is terrible, when the driver is supposed to be 2.8 amp, (I know, it will never be 2.8 amp in real life, but it should be close!).
I did not realize just how much resistance there is in these cheap battery holders!
Also, I learned a little about the 105c driver.
3AA Eneloops (no holder), with magnets between them - 1.4 amps on High
4AA Eneloops (no holder),with magnets between them - 2.6 amps on High
That tells me, the driver does not regulate properly until the voltage is higher than I would have thought. I was always under the assumption that 4AA NiMH would cause the driver to heat up, due to wasted voltage, but actually it did not even "come alive" until the 4th NiMH was added. I remember reading somewhere, that very fact and now I believe it too.
I also discovered something else. With the batteries hooked up with the magnets between them, there was "No Humming" from the driver. With the batteries in the holders, there was "Noticeable Humming" in the driver.
What I learned, is that I need a permanent test station, where I can test each build, before it gets put into the light. I also learned that one of the reasons some of my lights were never bright, was due to me using 3AA battery holders, which cannot even begin to give the amperage needed. I realize that 4AA NiMHs are necessary for any build using a NANJG driver.
So, from now on, no battery holders in my builds. Nothing less than 4AA batteries in my Maglite "D" builds.
This will complicate things... but that's life.
Oh, the Eneloops are less than a month old and were freshly charged (two sets of four). The NANJG driver was new and so was the Judco 5 amp switch. All connections were soldered except the battery + and -, which were held by the pressure of my fingers pressing hard on the terminals.
What are your thoughts?
EDIT: Second Night
I modified the 4AA battery Holder with copper contacts and gold plated springs (gold looking springs, I should say)
4AA Modified Holder - 2.6 amps on High, that's the same as 4 Eneloops with no holder, only with magnets.
This means the modified holder has very little resistance.
I also tried Direct Drive with 3 and 4 Eneloops
3 Eneloops, No Driver - 1.2 amps.
4 Eneloops, No Driver - 2.8 amps and then the led went very blue and very dim.
In other words, without a driver, the amperage is more dependent on the voltage. At 3.6 volts (probably more like 3.3 volts with sag), it only achieved 1.2 amps, even though the Eneloops could supply more. At 4.2 volts, it achieved amperage so high that the LED shut down (cooked).
It will be interesting how an XM-L will fare with these tests.
