Nitecore d10 help!!!
I have a nitecore d10 (old I know) that will not power on. The spring is missing from the battery tube but that’s not the issue. There is a component damaged that I can not identify. Please help me figure out what it is, please.
I’m pretty sure that is busted as it has a hole in it. Thanks
I’m in the process of putting a BLF15dd v3.0 in my D11, I’ve got a lot on my plate and it’s pretty low priority but if you want to drop me a quick PM so I can remember who you are I’ll keep you updated on my progress.
Looks like a diode to me but its not clear enough for me to tell for sure.
The roundish mark in the center is just damage? Any printed markings on the component? Diodes usually have a line (faint sometimes) toward one end.
Yes it has a faint line and what appears to be OS or 50. The rest has been blown off :frowning:
Might be a schottky diode that just serves for reverse polarity protection. Which side is the line on? Can you tell where the circuit traces from that component go?
Did the D10 have a physical ring that blocks contact from a reversed battery? If it had a physical reverse polarity protection ring it wouldn’t strictly need a diode for that purpose.
That’s it! Now on to find one. Thanks.
Are you sure you now know exactly what to look for?
There are many different diodes out there, so, I’d verify first.
Was this one repaired or is it factory?
Woot!!! So just for kicks I unsoldered the bad diode and replaced it with one I had laying around a bit under 1a. And it came on. I just did this as a test for function. So now I have to find one to fit.
Mine is original. it’s a pretty old version. I got it from Foursevens at CPF years ago. It has an Osram Golden Dragon LED.
Thanks for the help all. Now I just need a pic of the spring out of the light with a measurement.
:slight_smile:
I’ve owned tons of budget lights and became hooked on the more expensive nitecore d10/d11 and EX10/11 lights. I truly believe the D10 is the coolest (did not say “best!”) flashlight ever made. They are a little quirky, like a classic car, but there’s just nothing else like it.
Congrats on limping yours along
Congrats on finding the cure. D10 and EX10 are my all time favorites.
Anyone have pics of the spring?
I can take some for you tonight if none are up by then.
Thanks!
Well I killed it ;(. Burnt the pad off the board. The kids were running in and out of building and my hands were shaky. Should have known I’d screw it up. Oh well at least it worked for a short time :frowning:
Sorry to hear that. :frowning:
Small surface mounted components can be hard to hand solder. A good soldering iron (temp controlled if possible), good solder & flux makes things easier.
Even if the driver is truly dead don’t toss the body. Is it in good condition?
Mine’s different, there’s “SL 50” printed on it, soldering looks much better too. I have coloured limited edition with XR-E Q5.
