Hello BLF members!
Please help me choose between these two flashlights: Nitecore EC25 and Solarforce P1d (body)
I’m Neutral White Newbie, therefore definitely will choose EC25 NW version.
but I like also Solarforce P1d body. In this I plan to put in self-made XM-L2 T6 3C p60 drop-in with LD-25 2.6A driver.
The final price will be similar for both.
After all, I want to say - I like self-made flashlights (drop-in’s) because they are a more personal.
But more I trust, however, to the branded product - where everything is factory assembled. I also like the modern user interface in EC25.
If the price is similar and it had to be one or the other I would go the nitecore EC25. I love my solarforce P60 dropins, but the latest nitecore lights are just way too cool. Not to mention they are premium lights with top build quality. And yes, go the NW.
I can only comment on the P1D… as Foy noted, it’s nice and you’ve got all kinds of flexibility with p60 dropins. However, it doesn’t tailstand and it comes with a forward clicky switch. (I found that I needed a bit of wire tucked into the tail when I switched to a reverse clicky.)
Yes, thanks for reminding, but here I am talking just about input voltage. In P1d I would put self-made drop-in, which can hold only up to 4.2V (or a little more).
Basically I will use it only with 18650 cell, but it would be nice if it could work also with CR123A’s which could carry with you for emergency situations (when going somewhere for a longer time)
and however…
researched information about EC25, and there’s something that I do not like.
The electronic switch is stylish, but… I realized that it is too complex. Flashlight should be easy to use. Simply “click” and turn on, “click” and its turns off.
One more thing: according to the manufacturer’s data - EC25 on Turbo able to run up to 1h30m (and it is by using Nitecore 2600mAh battery). This means that the turbo mode consume only some 1.7A - 1.8A (definitely no more). Therefore 860lm is quite questionable value…
So that I will stay with Solarforce… with XM-L2 @2.6A it will be brighter, easier to use, and it will also be easier to upgrade.
Both are excellent choices. The EC25 is really just an upgraded version of the MT26 which I already own, so the only main reason for getting it would be for the side switch interface. Since I have a plethoria of side switch torches already, I prefer the tail switch for rugged use, and no nonsense interface.
I ordered a P1D (my first P60) just because of its unique styling. More and more I’ve come to appreciate tactical tail switches handiness. With a P60 I can easily experiment with different tints and CRI emitters.
Yes, indeed, discount codes will be useful.
Thank you again.
This Nitecore has everything what I want… + USB charging option (It is a great option - charge it in car from a mobile phone charger)
That I believe would be a good choice, I have one waiting for me when I get back on holiday. These nitecore flashlights, whilst being different from P60’s, are better value IMO than a solarforce P60. I love my L2T’s and M2M, but I value my MT26 Nitecore more. Re the runtime on the EC25, it has a stepdown after 3 minutes to around 500lumens, so the runtime is plausible. The P25 stepdown is after 20 minutes, it stays brighter for longer.
