Nitecore HC65 V2 Review (SST40-W, 18650)
Bright main light, good additional floody and red, fast built-in charging, full brightness stabilization and full-fledged 900 lumens mode (with some fan cooling) - Nitecore HC65v2 unexpectedly turned out to be a model that i really liked. If you are looking for a branded headlamp with additional light, then I hope that the Nitecore HC65v2 review may come in handy.
official product page
➤ Amazon
STATED CHARACTERISTICS
LED Luminus SST-40-W
Maximum brightness 1750 lumens, maximum range 165m (7000 cd)
Optional LEDs: 4500K HiCRI low beam and red light
Shooting range optics
No PWM flicker
Overheat protection with brightness reset
Built-in USB-C charger
Aluminum housing
Hard anodized HA III quality finish
Water and dust resistant IP68 (submersible up to 2 meters)
Impact resistance - up to 2m
DESIGN
Definitely, the package design of the latest Nitecore models is much nicer than the previous ones.
The kit includes the headlamp itself with a head mount, a 3500mah 18650 battery, a type-c charging cable, a pair of o-rings, a manual, and a warranty.
The headlamp is made in a classic T-shaped form factor and has standard size for it, standing out only with a wide front panel with TIR lenses. It certainly looks impressive, you can immediately see that this is a branded item.
Headstrap is good. Not perfect, but just good. The fabric is soft, there is a gel strip inside. No light reflective elements. I’ve seen worse and better. Strap of Nitecore UT27 is exactly what i`d like to see here.
The headlamp mount is classic, with rubber eyelets, so the headlamp can be completely pulled out off this mount in case of need.
On one end of the flashlight is a Type-C charging connector. The charge current here is wonderful, so you can charge quickly. There is PD support! You cannot use the flashlight while charging.
As you can see, there is a special “leash” not to lose the headlamp cap.
As expected, the battery is inserted from the opposite side. There is only one spring, The small peg of the contact pad is seen at an opposite side, everything is as usually here.
I note that the inner diameter here is comparable to the diameter of a 21700 battery. I think that Nitecore could add a millimeter in diameter and 5-6mm in length to power this headlamp by a 21700 battery.
Nitecore HC65v2 is run by one button. As usually, it has backlight to indicate battery voltage and state of charging process. The 1st is damn convenient to estimate the remaining operating time.
The button mode is mid-deep with a slight click. There is nothing unusual here. Pretty handy button.
And here is the interesting part of Nitecore HC65 v2 review. Let me remind you what the optics of the previous version looked like
Now both the near and red additional lights have their own TIR lenses.
This is whole plastic panel with lenses, without glass covering it ! This may repel someone, but I have been using a headlamp with a plastic lens front panel for three years now and absolutely have no problems with it.
Don`t be afraid of it guys, it might be better (i mean glass upon plastic), but it is still Ok.
This is what it looks like live
You have an easy access to insides, in case of need. Just in case you would like to change primary LED with some 5000K one.
UI
Well, good UI, with little specific part. Not in the sense when reviewer says “specific” instead of “bad”.
What i mean - the unusual thing here is that when you click button you turn on moonlight mode by default.
And if you hold button, you turn last used mode.
Usually, that is vice versa. I don`t know why Nitecore changed well known UI. But, well, that is still OK, as you have an instant access to moonlight and last used mode.
The rest is as usually - click to switch modes, hold button to turn flashlight off.
2 clicks - switch to special modes. And here I would prefer to have a mode memory, so that you can immediately turn on near range floody light.
Now this mode is the very last one, after red light. On the other hand, the fact that red is turned on first by default is good when you turn on the headlamp at night,so you can to preserve night vision.
HOW NITECOREM HC65 V2 ILLUMINATES
Nitecore hasn’t surprised me in such a good way for a long time! The flashlight perfectly reacts to any cooling.
When i left it in a balcony, where were +10C, that led to ~15% increase in brightness, i.e. up to 800-850lum! And this is a stabilized long-playing brightness.
If, under the same conditions, we also add fan cooling, then turbo mode starts to work to the maximum. Yes, you lose some runtime, but the flashlight will actually shine like a star.
Well done, I didn’t expect that. It’s all the more sad that the HC65 v2 doesn’t support 21700 batteries, with which the runtime would be really impressive.
As for the light and the modes spacing, then I have no reason to complain.
Ah, of course, I would prefer the main LED not to be cold white, to have 5000k color temperature, which is no problem for SST40 LED. The headlamp would be just little bit, insignificantly less bright, but it would get rid of the light tint and just looks way better overall.
But as is, Nitecore HC65v2 gives excellent light in terms of maximum brightness and unexpectedly good light in terms of range. You can highlight an object ~100m from you in case of need.
An additional LED is quite convenient for close work. The red light here is very bright and, which is extremely rare, has two levels of brightness.
50m.
turbo mode give really good throw.
and here is video review
OVERALL IMPRESSIONS
wow, the Nitecore HC65 v2 is the best Nitecore flashlight I’ve had since… mmm… perhaps my favorite EC4GTS
It has absolutely everything that can attract an ordinary user:
impressive turbo mode, far from decorative runtime of super-bright blitz
the work of thermal control, which will gives you visible effect when work outside with some wind cooling, not to mention winter.
fast 2A type-C charging
very convenient UI
additional floody light for near range work
two levels of bright red light
But still there are 2 CONs for me personally:
the 1st is completely expected - the cold light of the main LED. that is not a problem for a lot of users.
the 2nd - I am sure that this headlamp certainly deserves a more capacious 21700 battery.
If we talk about big brands, about 18650 headlamps for a regular user, then I tend to think that this headlamp is most likely to be the best one on the market now. At least of the ones I’ve had in my hands over the last couple of years. It’s not cheap, of course, but for the price you get everything you can possibly get.
Actually, I think that even an advanced and sophisticated user will find the Nitecore HC65v2 a pretty good flashlight.
Ok, i`ve said lot of sweet words about this model. So i have to remind that those, who constantly read and watch my review, may notice that I am far from being enthusiastic about the latest Nitecore models and criticize them for short turbo and expensive proprietary batteries. So, i`m honest, guys. Just take a look at my previous review.
That`s why it was so pleasant to finally say something that I had not really said for a long time, and now I am ready to say it. Well done, Nitecore, bravo! That is damn good model.
So, dear reader, if you want to choose 18650 powered headlamp by big brand, headlamp with additional lights - here you are. If you buy HC65 v2, I’m sure you like it. It will be interesting how the rival brands respond to this model…
updated with new pics and video review
Thanks for the review!
Another nice review :wink:
UI and the CW emitter are not my type, but seems a good looking and good working headlamp :+1:
Nice review. I have the older HC60 and love it. If it ever permanently stopped working, I would probably either get the HC65 V2 or the HC68.
