I have a fairly new (about 6-8 months old) notecore intelicharger i2 v2 and it appears to have a problem with the second channel (when looking at the charger from the left)… it seems tha it terminates charging at 3,92V when the other channel terminates at 4,25V…
when I switch the batteries the first channel charges the battery fine so it is not a battery problem…
so basically i have to switch channels when charging finishes to have both batteries charged at the same state…
it also does not occure every time i use the charger…
If the “good” channel is terminating at 4.25v, which is on the high side, I think that the “bad” channel is going to a high enough voltage to sometimes trip the over voltage protection of a cell.
