Nitecore i4 Blue indicator light not working
So it seems to be charging fine but no blue light. Got it recently from fasttech.
Do I need to be concerned ?
Have you also tried it with a 12V power supply? I use mine with a 12V adapter because it gets warmer when used with 110/220V.
Since you are saying everything else is working fine, maybe the blue led is fried? Or bad connection? Have you tried to crack the charger open?
Edit: does it always acted like that? If yes, you may try to get an exchange or refund from fasttech…if it’s not too late.
Not sure why yours isn’t on. Mine says lit blue at all times when its plugged in. Charging or not.
same here
It used to stay lit all the time when plugged in but not anymore.
The LED is probably just fried. If that’s the case I probably won’t bother with an exchange from FastTech.
same here……I’d contact FT and see if you can get a replacement. You kinda need those lights to tell when its done charging
The yellow lights work though. Just the blue power one is dead. if it isn’t a sign of more trouble inthe future then I really would rather not deal with fasttech.
why not, they can’t bite and its a rather critical feature
do leave a battery on it longer though, a fully drained battery on a good charger will take a lot longer then expected if the charger charges a fully drained battery at a low rate till the charge level is higher, i had a charger that took more then twice as long on a fully drained 26650, but if i only half drained it then it took the expected time.
