nitecore MH12GT questions
Fellas how tight is the battery held and what is the spring set up in this flashlight? Looking to use it as a budget gunlight( pest animals at night from a low recoil carbine, not bad guys, so I dont need surefire). If the battery rattles back and forth openly, or is likely to hammer the button top at one end on something solid, that maybe a problem. Thanks for your thoughts.
Battery will hammer the driver contact plate as there’s no spring there. I lost my MH20 after a pretty short drop on a hard surface.
Thanks Phantom23, its a no go then. Anyone know if a Fenix UC35 is set up to handle things any better?
One of the S-series Convoys (S3? S5?) had a rather “precise” fit and limited clearance that it wouldn’t even fit a protected cell. Such short travel could lock in the cell pretty snugly and not let it bounce around too much.
Just looked, it was the S5…
https://www.fasttech.com/products/1618/10002463/1319908-convoy-s5-diy-edc-led-flashlight-host
Only took unprotected flattops.
Well, if you can snag one, go for it…
