Nitecore MH25 V2 revew (21700, type-C)
We all know that flashlight manufacturers do all the possible to reach maximum possible numbers of throw and brightness in specs. So I didn’t even expect that such a big brand as Nitecore would take a break in this pursuit to release a usual flashlight, not a wow thing. Just sort of reliable a workhorse for those who need compact long thrower with good runtime. So is Nitecore MH25 v2.
you can buy Nitecore MH25V2 at:
➤ AMAZON
PACKAGE and APPEARANCE
The package looks damn good, much better than well known traditional Nitecore black and yellow boxes.
By the way, there is also a hunter-kit which includes color filters and gun mount with a remote switch.
Usual kit includes everything you need: the flashlight itself, 5000mah 21700 battery and 18650-21700 adapter, a clip, a lanyard, a Type-C charging cable, a holster , a manual, a warranty.
Nitecore produces multitasking flashlights in MH models line. And this one is fusion of tactical and long-range flashlight. Well, as a tactical model, it has absolutely ordinary size. And if we treat flashlight as a long-thrower, it is relatively compact for its class . Relatively, because the small diameter of the head is compensated by the hefty overall length of the body.
I personally like this size. The flashlight has an excellent balance, comfortable and firm grip.
One would expect the design to be the same as that of predecessor Nitecore MH25S (review) or old MH25GTS . But no, design of this novelty is modest to the point facelessness. There is nothing outstanding in design at all.
MH25s
MH25GTS
Nevertheless you can see that this is a brand and well designed flashlight. Which is what it is. But not more. On the other hand, it is a flashlight for working, not for admiring it or keeping stored at shelf. I suppose that this is enough that it looks good. And it definitely does!
Of those design changes that influence use, i can highlight traditional layout of the tail button. Now flashlight has a tail-stand (although i believe that few needs it).
There are springs both at tail and head sides .
The knurling is quite tenacious. Again, the flashlight has a really good grip.
The head is not that wide, especially relative to its length. There is a lot of quite deep cooling fins.
As usually, the side button and the charging port are at the opposite parts of head.
Side button is clicky, with average deep move. There are no problems blind find it, no matter barehand or in think gloves on.
The charging port cover is thick. It never accidentally opened while i used Nitecore MH25 v2 for review purposes.
Bezel is far away from being tactical: it`s teeth are wide and low. The bezel, of course, is sealed - the head is not separable.
The reflector is smooth and quite deep. I have no idea what LED is used here. All i see is that this one is quite large, larger and XHP35 HI of Sofirn C8G and SST20 HD of Nitecore P20i UV.
Comment if you think you can recognize this LED.
UI
Sort of well known classical UI used in damn lot of flashlight with both side and tail buttons. Convenient for wide masses of users
On-off - tail button click.
Switching modes - side button click
Special modes (sos\strobe\beacon) - side button hold.
By the way, if you switch to the tactical scenario, modes will go from High to Low and side button hold will activate only Strobe.
There is a memory of modes.
I’m not really into tactical flashlights, but I think a tactical flashlight should still be able to access the strobe from off, not only from ON like here.
HOW NITECORE MH25 v2 ILLUMINATES
The brightness is well stabilized, flashlight performs excellent when there are some cooling, keeping maximum brightness for a long time. As this is a flashlight for outdoor use, you should expect this good runtime in high mode. As you can see, MH25 v2 performs well even after immediately reactivation of high mode.
Though mode spacing is good in low levels, it definitely lacks intermediate mode between huge gap of High and Mid. Sort of 700lumens. I believe that flashlight can keep such a brightness well stabilized even without any cooling. Actually, i also believe that more bright SFT40 would be better choice here, instead of this whateverer-it-is LED.
The flashlight has a long-range light with pronounced hotspot and dim sidelight. It will be, of course, inconvenient for near range work, but performs its best from around 30-50m. Or, of course, if you need focused light for sort of indoor tactical use where you shouldn`t blind your mates with side light.
I was astonished to see not cold, but neutral white light here. That so damn good, but i really don`t like a visible green tint of this LED.
It is clearly seen in winter when i point flashlight on white snow. But i must notice that when you use Nitecore Mh25 v2 in summer, when there are lots of trees and grass around, such a green tint simply disappear. Anyway, i warmly welcome the fact that Nitecore refused of Cold White LED in this model.
However, this does not in any way negate the fact that I`ve always criticized such a tint shift.
As for the range, there is nothing astonishing here. They just good, but nothing more.
Yeah, it would be possible to achieve impressive range with the same modest brightness of 1300lums by installing some kind of trendy Osram LED. But even as is, the flashlight works quite confidently within a radius of about 250m and gives, in general, useful light up to 400m. Or SFT40 could be used here, giving like half more brightness with damn good throw. I believe that exactly this LED would be perfect for MH25S V2.
Again, Nitecore MH25 V2 doesn`t impress with it`s brightness and throw only by modern standards which are frankly crazy high (throw is largely set by the same aforementioned Osram LEDs). But if you remember that we are talking only about 1300lum maximum brightness, then you understand that the throw is not that bad at all.
OVERALL IMPRESSION
Let`s count advantages. There are a lot of them:
Brightness is moderate, but it is fully stabilized and the throw is good for this brightness.
Light is not Cold White, like you would expect of Nitecore, but really neutral white one (though greenish)!
21700 battery with long runtime and fast charging speed.
Body is well designed, grip is comfortable and firm
UI is understandable to any user.
3-4 years ago, such combination of brightness, range, size, runtime and speed of charging, brightness stabilization might have made this model a bestseller.
All these advantages make me even forgive really, really greenish light which i`m usually strongly against of. I honestly admit that chances are low that user will notice such tint during summer outdoor. I have absolutely nothing against the rest of flashlights functionality besides lack of intermediate mode between high and mid.
Now, again, such brightness is quite common, and so is the range. The standards have grown, after all. There are a lot of 21700 flashlights on the market, and type-C charging has become the standard. So this is not the flashlight that will surprise you.
And, you know what, it seems to me that this is only for the best. Nitecore MH25 v2 shows quite reasonable specs of brightness and range that are sufficient for most users. I clearly understand what could have happened if Nitecore had chased big numbers in specs for this model. Loss of brightness stabilization, a symbolical maximum brightness. All for the sake of numbers, attractive and impractical. There are a lot of examples of this on the market.
Nitecore MH25 V2 is just a workhorse and closes the corresponding empty niche of the manufacturer model line. It’s just a long lasting compact long thrower. I repeat, brightness and range are, no doubts, sufficient for most of regular needs. It has a capacious battery with fast charging and excellent runtime.
The result is a simple compact long-range flashlight. If you need light within a distance of 50-200m, if you fundamentally need a flashlight from a large well-known brand and if you are ready, according to the latter, to cover the accompanying considerable price, then Nitecore MH25s v2 will please you. Or not…hope this Nitecore MH25 V2 review will give you answer to all you questions about this flashlight
Is it my imagination or is 1300lm a bit too weak for a light of the size and style.
