So fooked the wires while disassembeling SRT5 head for emitter swap.
I can see ehere Neg is soldered but where in the world Pos should be soldered to driver?
Anyone?
Does Red positive thick wire goes oposite os Black? Can’t see any trace where it could be 8/
If you have a DMM —- put it on the continuity setting —- put one lead on the pos + terminal where the battery touches— start touching around the other side till you hear the beep
Dang...how i missed that part
Yes sir, will do that and conform my readings in the morning.
Since the LED is in fact a diode, if it doesn’t work don’t hesitate to reverse your probes.
could be a buck driver so does not need to go to battery +
